2006 Civic EX w/ check engine light & codes: p2183, p2185, & p0111
Old Sep 27, 2008 | 12:28 PM
TiaMarie's Avatar
Question 2006 Civic EX w/ check engine light & codes: p2183, p2185, & p0111
Hi!
I am hoping someone can give me an idea of how costly these repairs will be - or are these codes too general? I know the first two are mostly the same thing. One has to do with the coolant sensor, and the other has to do with the air intake sensor.
I just found a technical service bulletin with the following info:
Component Description:
2. ELECTRICAL SYSTEM:WIRING
Bulletin Number: A08030D
Bulletin Date: Mar 08
Vehicle: 2006 Honda Civic
Summary:
MIL ON WITH DTC P0111, P0128, P2183, OR P2185? CHECK ECT SENSOR 2. ( NHTSA ITEM NUMBER - 10024896 )
These are the codes that are showing for my car. Does this mean that the Dealer would know this - is this like a recall? Sigh...
Also if anyone has experience dealing with warranties and Honda and has advice, let me know.
Thank you!!!
Old Sep 27, 2008 | 01:49 PM
Try for a "good will" free repair from Honda when your car is somewhat out of warranty but it has a problem covered by a TSB. This would be done by going to a dealer and having them talk to corporate.
The ECT sensor is probably not very expensive but the IAT sensor is built into the MAF sensor so both are replaced as a unit, and MAF's tend to be expensive.
Old Oct 2, 2008 | 04:27 PM
TiaMarie's Avatar
Question Any Idea of the $
Do you have any idea how many hours of labor it would take to replace both? I guess I am trying to figure potential costs and compare that with a quote I am going to try to get from the dealership if I can't get any "assistance".
Thanks for taking the time to answer!!!
Old Aug 23, 2009 | 05:32 PM
jlawrence's Avatar
I'm getting the same problem... MIL ON WITH DTC P0111, P2183, and P2185... any chance you know what fixed your problem or if you have the details for the TSB?
Thanks!
Josh
Old Sep 28, 2009 | 08:51 AM
jayburtonboy's Avatar
Same problems. Any suggestions??
Old Sep 29, 2009 | 04:07 AM
jlawrence's Avatar
yes, I found more info. It's probably a loose or corroded connection near your ECT-2 sensor on the bottom of the radiator.
See page 5 on the PDF located here: http://www.in.honda.com/Rjanisis/pubs/SN/a080300.PDF
Also, more info in this post: http://www.honda-tech.com/showthread.php?t=2461422
My car is past its warranty, so I plan to check the ECT-2 sensor myself (haven't got to it yet). I wonder if we would be able to get a goodwill repair from Honda...
Old Oct 3, 2009 | 04:58 PM
jlawrence's Avatar
Default Sure enough - ECT 2 sensor connection was corroded / broken
I just checked the connection at the plug for the ECT 2 sensor, and one pin from the sensor was indeed broken off in the hole of the connector...
Old Sep 14, 2011 | 06:07 PM
maminej's Avatar
Hi
I have the same problem here with my civic 2006.
My check engine light is randomely coming up and i guess it's simply a connector issue. (the light actually goes down by itself, without reseting it with my OBD2 reader).
I found this very interesting but the image is kind of not very clear to me
can anyone help me finding it
Thanks
Old Sep 14, 2011 | 09:25 PM
The picture was taken from underneath, with the car up on a lift. The sensor is on the bottom of the radiator toward the left side. If it's like older models, there is a black plastic splash shield on the very bottom of the car that will need to be removed first to have the view shown in the picture.
chmiller25
Jul 23, 2012 11:50 AM
towelie
Aug 30, 2010 05:08 PM
Methu969
Jan 22, 2007 01:13 PM
mobbology
Nov 29, 2006 05:37 PM
emericanidol
Jan 19, 2006 12:47 PM
