95 civic dx fuel/electrical problem
Old Dec 11, 2008 | 06:34 PM
mike1969fl's Avatar
Default 95 civic dx fuel/electrical problem
95 civic dx SOHC
engine will turn over but no fuel
when i turn the key, sometimes the pump will not prime, therefore wont start
pump is fine i checked it and tested it
my question is, where is the relay under the dash? how do i test it?
would be greatly appreciated, its my daughters car.
thanks
Old Dec 11, 2008 | 07:11 PM
zeplin's Avatar
Old Dec 11, 2008 | 07:19 PM
mike1969fl's Avatar
so would it be the srs?
Old Dec 11, 2008 | 07:21 PM
zeplin's Avatar
Now that I am unsure of. You could try asking in that thread, someone may be able to help you. Otherwise you can wait for RonJ to respond, he knows everything
Old Dec 11, 2008 | 07:22 PM
The diagram below should help. The fix is to replace or resolder the main relay (see link in my signature).
Old Dec 11, 2008 | 07:24 PM
zeplin's Avatar
See? ^_^
Old Dec 11, 2008 | 07:40 PM
mike1969fl's Avatar
so if i am not misunderstanding you, because the pump does work sometimes it is a bad relay?
Old Dec 11, 2008 | 07:48 PM
mike1969fl's Avatar
and if i replace it, what does a new relay cost?
Old Dec 11, 2008 | 08:16 PM
The main relay of 5th generation Civics is a well known problem. Given that your fuel pump is fine but intermittently doesn't work, the main relay is the prime suspect -- it provides power to the fuel pump. I think a new main relay runs $35-$40. If you can solder, then the cost of repairing the main relay is much less.
Old Dec 11, 2008 | 08:21 PM
mike1969fl's Avatar
thanks, ill see if i can find it in the morning and see what i can do
