Engine noise when cold
Old Dec 31, 2008 | 12:28 PM
cloudbreakmd's Avatar
Question Engine noise when cold
I have a 1997 Honda Del Sol 5 speed Si (SOHC Vtech). The engine makes a noise when it is cold almost like a low pitched whining (almost like gear noise). Turning the wheel left to right makes no difference. The sound exists whether the car is moving or stopped. I changed all the accessory belts 3 days ago. The engine sounds normal once warmed up. Any thoughts?
Old Dec 31, 2008 | 12:32 PM
Additional maintenance done this week:
Coolant changed
Gear oil replaced with Honda MTF
Oil and Filter changed
Clutch flushed
Brake Fluid Flushed
Power-steering level checked
I don't think any of this stuff is related but I thought I would mention all that has been done.
Try to localize the noise. Might be a bad bearing in the idler pulley, power steering pump, alternator, or even water pump.
Old Dec 31, 2008 | 12:49 PM
I did a search and it recommended using a long piece of tubing. I just got this car a week ago and am still familiarizing myself with it.
Old Dec 31, 2008 | 01:20 PM
Yeah, a piece of garden hose-sized tubing will help localize the noise. The idler pulley is connected to the A/C compressor belt.
flyn2lo48
Nov 21, 2011 01:58 PM
general23cmp
Dec 20, 2008 10:43 PM
cjlacroix
Sep 28, 2008 11:01 AM
ltkenbo
Feb 28, 2008 01:08 PM
ehantny
Dec 28, 2006 02:10 PM
