92 civic over-heating
Old Feb 23, 2009 | 06:54 AM
Dipsetcivic117's Avatar
Default 92 civic over-heating
so i just noticed that when i turn my heat/ac temperature to blow "cold" my car starts to over heat. But as soon as i turn it to the "hot" the needle drops down and stays at normal/half. The radiator fan turns on and it is filled with antifreeze. any ideas what it might be. wanna fix it before the heat comes. or imma die
Old Feb 23, 2009 | 06:58 AM
mudferret's Avatar
Sounds like a stuck t-stat. Cheap/easy to replace.
Old Feb 23, 2009 | 07:16 AM
I agree, after making sure the coolant is not low and the fan works, the next step is to just replace the thermostat. If the problem persists, investigate further.
Old Feb 23, 2009 | 06:04 PM
iight. thanks alot. and now my heater blower seems to stay on even when my car is off and the keys are no longer in the ignition. any1 have an idea on this 1. i had the car for about 7-8 months and just today this happend. its so wierd.
Old Feb 23, 2009 | 06:29 PM
Originally Posted by Dipsetcivic117
...and now my heater blower seems to stay on even when my car is off and the keys are no longer in the ignition. any1 have an idea on this 1. i had the car for about 7-8 months and just today this happend. its so wierd.
Does the blower stop running when the blower switch is turned off? If so,:
Test #1: Check whether there is battery voltage at fuse 13 when the key is turned OFF.
Test #2: If Test #1 shows no power at fuse 13 with the key OFF, then test the heater motor relay (see diagrams below).
Old Feb 24, 2009 | 07:58 AM
The 3 relays in a row in the box are identical, so you can pull out the rear defogger relay and try it to replace the heater relay to see if that resolves the problem. If it does, you need a new relay.
Old Feb 24, 2009 | 06:28 PM
iight. ill try that when it gets little warmer. cuz now the fan does it sometimes. and what i noticed was if i smack/punch the heater control deck thing, it will shut off the heater/heater lights. some im guessing it must be a wire thats in the back that is loose or something since i can hit it and it will shut it off/on. kinda ghetto.
redlillian
Feb 21, 2020 12:22 PM
Chris0226
Aug 26, 2012 07:39 AM
sramelyk
Mar 6, 2012 04:54 AM
Love_Honda
20
Feb 18, 2009 12:59 PM
hondarob
Oct 23, 2007 05:12 PM
