Need to do an oil pressure check
Old Feb 28, 2009 | 05:48 AM
asechrist's Avatar
Default Need to do an oil pressure check
I would like to try to perform an oil pressure check on my '95 Civic DX, as the engine makes a ticky sound (especially when warming up - but still smewhat even after). I checked the valve clearances and they were all within specification. A little while back, I purchased an oil pressure tester from Harbor Freight, but I would like it if someone here could tell me what the oil pressure should be at idle for my car. I'm not keen on trusting the numbers provided by the piece from HF. If you know of a place for me to find a description of the procedure, I'd appreciate that too, as it's not included in my Haynes. Thanks a lot,
Andy
Old Feb 28, 2009 | 07:47 AM
Old Mar 16, 2009 | 03:00 PM
asechrist's Avatar
Thanks Ron. I haven't had a chance to deal with this yet, but I do have one question before I get to it. My car does not have a tach mounted, so I will hve to attach one, as the instructions direct. I'm sure this is probably simple, but how do I go about attaching a tach on my car for this test? Thanks again,
Andy
Old Mar 16, 2009 | 08:09 PM
danomatic93's Avatar
June 2010 ROTM
Make sure that the oil pressure testing unit's threads are 1/8" BSPT. Otherwise you could mess up your threads.
Old Mar 22, 2009 | 03:53 PM
asechrist's Avatar
My car is a Japanese built version. Is the 18" BSPT used in those?
Old Mar 22, 2009 | 04:43 PM
June 2010 ROTM
yes, BSPT (British Standard Pipe Thread) is metric pipe thread. NPT (national pipe thread) is American "standard" pipe thread.
Old Mar 24, 2009 | 04:38 PM
asechrist's Avatar
Thank you Danomatic. I will make sure that I have the correct hookup for this test. Before I do procede, I would still like to get some help with how to proceed in hooking up a tachometer to my car. Does anyone know how I should go about this? Thanks again guys,
Andy
Old Mar 24, 2009 | 05:53 PM
June 2010 ROTM
Either get a cluster with a Tach (it'll plug in without any modification AND WORK!), which I'm sell one on eBay right now, or you can buy an aftermarket Tach and use the Blue wire which connects to the cluster (pin D5). That wire is the signal wire for the tachometer from the distributor. Also, if you can't find oil pressure tester with BSPT I have adapters to got from BSPT to NPT.
Good luck!
lunger
Jul 10, 2011 02:50 PM
oilltd
Jun 10, 2008 04:06 PM
phan10m
Jul 7, 2007 04:27 PM
FlipHKD720
Apr 27, 2007 04:35 PM
