Were to get amp wiring stuff besides crutchfield
Old Apr 18, 2009 | 11:45 AM
BX_Civic's Avatar
Default Were to get amp wiring stuff besides crutchfield
Hey guys, is there any place other than crutchfield to get wiring stuff?
I need 4g wire about 10ft
8g wire about 3 ft for grounds
battery terminal
distribution block 4g in * 3 8g out
I need some small RCA cables but i know i can get those off monoprice for cheap.
So any suggestions?
Also im not a big ebay fan but if its really worth it then ill do it..
BTW:
How does this look:
http://www.crutchfield.com/p_211PSK0...n-PSK04RM.html
Has pretty much everything thing i need since i have my main RCA's in place already and have speaker wires in place.
The only additional thing i could possibly use is a battery terminal.
Old Apr 18, 2009 | 04:31 PM
well for the most part i can help ya out.... i got quite a bit of extra wire laying around.
so ya need about 10ft of 4gauge wire, a 4gauge to 8 gauge block, and some 8gauge wire, and a battery terminal.
let me go check to see all i got. i know i got a distro block...
Old Apr 18, 2009 | 05:11 PM
ok heres what i got. i believe its 10ft of brown 4gauge wire, 4gauge AGU fuse holder (ill include one AGU fuse i believe i have 60amp fuses i think maybe 80amp)
and i got a bunch of 8gauge wire red and brown. plenty of it.
i have 1 little 4gauge to TWO 8gauge wire, and another that is 4gauge to FOUR 8gauge wires. and one piece of 4gauge wire i think 4 or 5ft
no battery terminals tho... thought i would but nope.
5bucks for the block with only 2 8gauge outputs, and 20bucks for the monster cable 4 8gauge output block. that ones not cheap. think i paid like 40-50bucks for it at local ovation audio store.
15bucks for the 4gauge 10ft brown wire and 4-5ft 4gauge wire as well. tho ill have to actually measure it to be sure exactly how long it is. but im pretty sure it is 10ft.
and 0.25 per foot for the 8gauge wire your choice red or brown.
and 5bucks for the AGU 4gauge fuse holder and one AGU fuse dont remember which size i have but its either 60 or 80amp fuse. ill also include afew 4gauge crimp ring terminals if you need them. ya should just need 2, one for the ground wire and another for the main battery conection if you simply connect it to your stock battery terminal.
plus shipping of course...if interested that is...
ive also got some BEAST 1/0gauge wire also but i want 60bucks plus shipping for two 14ft lengths i have of used wire that ive used it in several vehicles now and dont want it on the new truck since its red and blue, i want silver for my new trucks wire.
Old Apr 18, 2009 | 06:13 PM
BX_Civic's Avatar
Ok i think were in good shape lets make sure these numbers are correct and well go from there:
I would like you to verify the length of that 4ga, 10ft should be enough but i would like you to verify for me.
15 10ft 4 ga Brown cable plus 4-5ft spare length
20 4ga to 4*8ga distribution block
18 12ft 8qa 6 red 6 brown
5 4ga Fuse holder with whatever fuse you have 60-80amp
that totals to 58 bucks plus shipping. my zip code is 10475 let me know what shipping is going to look like and i think were in business since this would be cheaper than buying all new stuff.
I would def need the rings for the 4ga cables (2) not to worried about the 8ga ones since im going to need a few and can prob score a bag of them from home depot.
Old Apr 18, 2009 | 06:49 PM
Superfly's Avatar
Are you going to run the wire under the the panels?
Old Apr 19, 2009 | 01:37 AM
ok ill check later tonight.
Old Apr 19, 2009 | 03:49 AM
BX_Civic's Avatar
Yeah ill run them under the carpet where they are not seen.
Can you see if you have any remote turn on lead cable as well. If not ill just have to get some from home depot.
EDIT:
Can you do 60 plus shipping and include both distribution blocks?
Old Apr 19, 2009 | 01:40 PM
ok well checked the wire and i actualy have 20ft of brown 4gauge wire. ya i sure screwed up counting that one... i had the wire doubled and forgot to multiply it.LOL
how about
70shipped.
both distro blocks, and the extra 10ft of 4gauge
20ft 4 ga Brown cable plus 4-5ft spare length
sorry no remote wire. i typically use that stuff for anything extra wiring i need so no scrap there. but that wire is very small and im sure it wont cost to much for it at home depo.
Old Apr 19, 2009 | 02:40 PM
BX_Civic's Avatar
Sounds like a deal man, PM your paypal and ill shoot that over right away.
EDIT:
Payment sent, thanks again for the good deal on this stuff.
hopefully ill get it before next weekend and i can try to wire up my new setup.
Old Apr 19, 2009 | 02:55 PM
no problem. just cut the wires and just need to get a box from work.
i got a bunch of stuff to ship out tomorrow
but on a good note for me my drop kit for my truck should be also shipped monday. now i just have to buy shocks for my truck.
sure ya dont wanna buy anything else. LMFAO
i need 150bucks more and ill have enough for shocks.
