need lower control arm
Old May 2, 2009 | 05:58 AM
Dipsetcivic117's Avatar
Thumbs down need lower control arm
so i wanted to get an alignment to put my new wheels/tires on...but had my girls dad check it before i brought it to the place.(they always try to play me when i bring my car somewhere...oh you need this you need that...we can fix it for you.) my question is..is any control arm good...like from autozone..or are those bad and i should get the from somewhere else. this is for lower control arm on the passenger side. i also need, i beleive, is a outter tie rod. the one with the boot. my boot was all cut up and was moving. thanks
Old May 2, 2009 | 06:28 AM
plethoric33's Avatar
You can go with the tie rods at the auto store, but I'd go ahead and get LCAs from a good company as they arent that expensive. I recommend Blox or Megan. I know several people who had bushing blow out with the Omni ones after only 6 months, so stay away from those. Ebay is the place to get them.
Old May 2, 2009 | 09:20 AM
What's the difference from the ones you mentioned above. Are they better then autozones. Are they ment for racing/looks. Or do you feel a difference. And should I replace both at the same time.
Old May 2, 2009 | 10:24 AM
Usually they are sold as a pair. They will be a better performing part than an auto zone part. They come in a variety of colors as well, they do look much better than the stock ones.
Old May 2, 2009 | 06:24 PM
I'm rockin blox lca's I have had them in for about 2 months now. Got them off of ebay for $105 shipped (brand new)
Old May 2, 2009 | 08:38 PM
I have heard numerous complaints about Blox and Megan Racing bushings. Get some Skunk2 LCAs or get the bushings replaced with Energy Suspension if you use the other brands.
Old May 2, 2009 | 10:14 PM
danomatic93's Avatar
June 2010 ROTM
Make sure the LCAs have poly bushings. Megan's suck, Omni suck, and blox suck. They all use cheap rubber bushings and will fail in a year, two at max.
Old May 3, 2009 | 06:23 AM
I had Blox ones for over two years with no problems with the bushings.
Old May 3, 2009 | 06:42 AM
June 2010 ROTM
^consider yourself extremely lucky, OR you got some with poly bushings.
Old May 3, 2009 | 07:54 AM
iight. so get them with poly bushing. got it. but the pictures you are showing me dont match up with what i saw under my car on the piece that my girls father was telling me to change. the piece looks like this...
http://www.autozone.com/autozone/cat...questid=771095
