transmission
Old Jul 24, 2004 | 10:33 AM
ZCJDMCIVIC's Avatar
Default transmission
I've got a 1994 honda civic running a JDM motor with a stage 3 clutch and aluminum flywheel i put in less then 5 months ago and my car started actting like it didnt want to accept the gears the past few days It acts alright as long as I start the car in 1st but when I do it gives a jolt forward but then It goes through all the gears alright but when I come to a stop or take it out of neutral it wont go back in any gears and if that isn't enough now when i lift the front end off the ground and start the car in neutral the wheels spin and the drivers side wheel is spinning faster then the other. I could really use some help advice on what the problem could potentally be. Thanks
Old Aug 3, 2004 | 05:28 PM
NTX's Avatar
NTX
Default RE: transmission
Is the clutch new? Could be an adjustment issue.
Old Aug 3, 2004 | 05:35 PM
i had a somewhat similar problem. it was a leaking clutchline, i tightened it up and refilled the resevoir, not a problem with it since.
mxer518
Mar 19, 2005 02:49 PM
slideman99
Aug 3, 2004 06:10 PM
Civic95Blue
Jul 29, 2004 10:09 PM
Importman04
Jul 27, 2004 10:11 PM
NYC Civic
Jun 18, 2004 03:46 PM
