gas smell
Old Jun 1, 2009 | 11:12 AM
justin07731's Avatar
Exclamation gas smell
i havea 91 hatch and every time i fill up i smell gas strong as anything for a very long time does any one have any ides bc ima pass out in there one day lol
Old Jun 1, 2009 | 11:18 AM
Are you overfilling the tank with gas? Have you tried to locate a gas leak? Have you inspected hoses of the EVAP system?
Old Jun 1, 2009 | 11:26 AM
yea i did noting on the tank leaks hoses good good i have a bad gasget some were or idk
Old Jun 1, 2009 | 11:28 AM
I'm not sure what you are saying here.
Old Jun 1, 2009 | 05:09 PM
petey9390's Avatar
Its usually the gasket at the top of your tank around your fuel pump and it will seep out and you will smell it coming up through your back seats.
Old Jun 1, 2009 | 07:31 PM
inthezoneac's Avatar
turn car on and see if any fuel is leaking around the fuel filter
Old Jun 5, 2009 | 03:04 AM
tradosaurus's Avatar
I have a 1996 Ford Ranger that has a fuel smell after I fill it up.
From all the research I did it seems that the culprit could be the rubber filler tube from the fill inlet to the tank.
I've bought a new one and will install it soon to see if that is the problem.
Old Jun 5, 2009 | 03:18 AM
Translation from wanna-be gangsta language to English:
Yeah, I did nothing (I assume he is suggesting that he didn't overfill). On the tank leaks... the tank is good, there aren't any leaks coming from it. Hoses are good. I have a bad gasket somewhere maybe, I don't know.
Old Jun 5, 2009 | 05:22 AM
Dipsetcivic117's Avatar
no he said,
"yea i did(check) and nothing is leaking from the tank. hoses look good.maybe its a bad gasket somewhere. idk.
Old Jun 5, 2009 | 06:04 AM
petey9390's Avatar
Bah ha ha ha!
