black smoke, bad rings?
Old Jun 24, 2009 | 09:03 AM
HondaEGcoupe's Avatar
Default black smoke, bad rings?
my 1995 eg started blowing a little bit of smoke the other day and i'm thinking its because of bad rings. anyone know more about this?
Old Jun 24, 2009 | 12:59 PM
Black smoke is usually a fuel mixture problem (too rich). Is the CEL on?
How much oil does it consume? When the rings are bad you'll be having to add oil every 1000 miles or less.
Old Jun 24, 2009 | 01:14 PM
PunisherInOKC's Avatar
Black = ok
White =bad.
Old Jun 24, 2009 | 06:45 PM
I'm not sure about the CEL and i haven't had to add any oil lately but i believe it does need an oil change. I just got the car not to long ago and was just wondering what it could be
Old Jun 24, 2009 | 10:11 PM
churritos567's Avatar
that may gbe the caser or the oil filter gasket may have melted on the block it happened to my 93 civic. i do recommend oil change. What punisher was talkin about white=bad means you have a blown head gasket or possibly your blowing your motor im nopt sure what hes going for.
Old Jun 25, 2009 | 01:16 AM
croninc's Avatar
white smoke sometimes means, ur fuel mixture is too lean.
Old Jun 25, 2009 | 08:37 AM
i'm pretty sure it's not blowing white smoke and i think the head gaskets fine. it may just be in need of an oil change because its getting somewhat dark
Old Jun 25, 2009 | 11:16 PM
change the oil, if it still blows smoke after an hour then check you air/fuel mixture im not sure how to work with that on pgfi but if it does post it up
-churritos
Old Jun 26, 2009 | 09:49 AM
hopefully an oil change does it but if not then the air/fuel ratio shouldnt be to hard to figure out...
Old Jun 26, 2009 | 09:51 AM
To learn about the important CEL, click the link in my signature.
