2 Sets of New Headlights Burned Out
Old Jun 25, 2009 | 08:26 PM
Maxxfli's Avatar
Exclamation 2 Sets of New Headlights Burned Out
I replaced my headlights about 3 weeks ago in my 1997 honda civic dx. They worked fine until yesterday when both the low beams burned out. The high beams worked for 15 more minutes and also burned out. So i picked up a test light to make sure the the switch on the steering colum was not faulty. The fuses for lows right and left and highs right and left were fine. I also unplugged the bulbs and tested the plugs which also had power. I replaced the 30amp fuse under the hood just in case. They guy at pep boys let me exchange the lights with no receipt and I installed them without touching the bulb this afternoon. They worked fine. I drove the car tonight and halfway through the drive the lows burned out. Turned on the highs and not more than 30 seconds later they burned out too. I had 1 old bulb in the car to replace one light. It got me home and did not burn out. Both sets that burned out are Sylvania High Blue lights ($30) a set. Not cheap stuff. My question.... Is it a short or a surge? Replace the alternator where the regulator controls electrical output?
Thanks,
Max
Old Jun 26, 2009 | 03:55 AM
SIMPLE..... you touched the glass bulbs.
DO NOT TOUCH THE GLASS.... the oil from your hands will create hot spots on the glass and they blow really easily!
so just change the bulbs and NEVER touch the glass on the bulbs only hold it by the plastic wire plug. if you touch the glass by accident then use some alchole and wipe the bulbs down good and let dry before you try again.
Old Jun 26, 2009 | 06:54 AM
Maxxfli's Avatar
I was wearing latex gloves the guy from pep boys gave me when I opened the package and installed them.
Old Jun 26, 2009 | 06:59 AM
Check the voltage at the battery with the engine running. More than 16 volts is definitely overcharging, in the 15's isn't so good either. You will have short life of bulbs, the battery, and other electrical parts.
Old Jun 26, 2009 | 07:04 AM
Yeah, I too was thinking that the problem might be a bad voltage regulator in the alternator.
Glenn22
35
Jul 9, 2011 12:29 PM
Lightsped
Aug 12, 2008 11:59 AM
Toppers
Dec 11, 2005 01:08 PM
PhilStubbs
Aug 27, 2005 11:07 AM
