99 Civic SI Tire Problem
Old Jul 20, 2009 | 08:48 AM
nathanswid's Avatar
Exclamation 99 Civic SI Tire Problem
The car originally came with 14" rims and during the summer months i put on 17" rims. I noticed when i put the 17's on that the tires were not fully even on the ground and this is including the front and rear tires. Both front and back tires are being worn out in the inside of the tire due to the full tire not on the ground. so pretty much its like \ / when you look at the tires.
If anyone has any ideas on what i could do to fix that problem please help me out or show me in the direction of a person who could.
Old Jul 20, 2009 | 09:35 AM
get an adjustable camber kit and you say \ / that would wear out the outer side of tires. now if its the inner side of the tire check inside of your fender wells to find wear tires are rubbing from when you turn sharp. also what tire size are you runing.
Old Jul 20, 2009 | 09:40 AM
is your car lowered? you probably need an alignment
Old Jul 21, 2009 | 06:56 PM
nathanswid's Avatar
The inside of my tires are wearing and i believe the springs have been lowered but i'll get pics asap.
Old Jul 21, 2009 | 07:11 PM
If the tires are like this \---/ and the inside of the tires are wearing funny then camber can't be the problem. It's probably your toe. I would look into getting an alignment.
budnjax
Jul 26, 2014 05:46 PM
civic2001
Jun 20, 2010 07:33 PM
kjsayers
Jun 10, 2010 10:06 AM
nathanswid
Jul 20, 2009 12:01 PM
civicchik94
Dec 31, 2006 09:58 PM
