F20C s2000 engine
Old Jul 23, 2009 | 02:27 PM
burnindesirez02's Avatar
Default F20C s2000 engine
Im sure its possible to swap it in an eg but just want to be sure that it will..and will an accord with an F series tranny fit on the engine?thanks...
Old Jul 23, 2009 | 03:13 PM
I've never thought of the F22 transmission working with an F20C. I've actually thought about the swap a lot, but without blocks and transmissions, I really can't figure out what would mate up with what. I know someone's swapped an F20C into an EK and kept it fwd, but he won't reveal what transmission he used. From the way the engine sits in the engine bay, I think he used a k-series transmission (maybe with an adapter plate and crank spacers like the H2B swap).
Old Jul 23, 2009 | 04:30 PM
Do a search on Honda-Tech for it... I've seen someone mention it but I don't remember what he said about the transmission. I remember he told us though.
Old Jul 23, 2009 | 05:39 PM
Brick's Avatar
Direct quote from the guy who did the swap on Honda Tech
f20c2 engine
k20a2 trasmition with jdm lsd
flywell f20c
pressure plate is k20a2
disk is f20c
relase bearing is b18c6 :asd
the engine mounth is innovative k20 swap in ek chassy
Heres the link. http://www.honda-tech.com/showthread.php?t=2505829
Old Jul 24, 2009 | 06:21 PM
In yalls opinion..Do you think it is worth it for the extra horsepower? Thanks for the info...
Old Jul 24, 2009 | 06:26 PM
just looked at the thread...why did he have to put it in backwards? Wouldn't it fit just like any other four cylinder engine?
Old Jul 24, 2009 | 06:29 PM
It's not backwards. It's oriented like a K-series, which is what the other generation S2000's came with (though they of course were turned sideways in the S2000, since it's RWD). Look at any K-series besides the one on the S2K and you'll see what i'm talking about.
P.S. If it were backwards, the wheels would spin the wrong way
Old Jul 24, 2009 | 07:01 PM
I know what he's talking about; the valve cover is facing the wrong way due to the way the engine is set up from the factory. If you look at the F20 in an S2k, the valve cover can be read right-side up when you're standing by the passenger-side wheel. Due to the way the fwd transmission has to mount, the engine has to be rotated so it looks backwards. It's simply because the F20C was designed with the longitudinal mounting it has in the S2k in mind when it came to aesthetics.
Old Jul 25, 2009 | 03:50 AM
Ah...ok i just thought it was weird that you had to do that...but alright...would it be worth it to try to do it?
Old Jul 25, 2009 | 07:06 AM
As far as money goes, I'm going to say not worth it. For the cost of the swap you could probably afford a K20A and spend a good bit of money on it.
thebadgator87
EK Swaps
Oct 16, 2006 10:43 PM
Smokinfast97
Sep 28, 2006 10:56 AM
Smokinfast97
EK Swaps
Sep 27, 2006 03:44 PM
Fiirkan
Mar 18, 2006 07:58 AM
95 Civic B16A
EG Swaps
Mar 9, 2006 04:34 PM
