map sensor question
Old Jul 23, 2009 | 04:36 PM
91_ef_hatch's Avatar
Default map sensor question
well i have a 91 hatch dx. stock 1.5 just had the new motor installed one month ago. now its smoking pretty bad. after it runs a while the white smoke goes awaythen just puffs a bit of black smoke. exhaust also smells bad. the shop said its not the motor its the map sensor.
so i guess what im asking is, is this a common problem in older hondas? thanks for reading my post
Old Jul 23, 2009 | 04:37 PM
I'm not sure how that could be attributed to the map sensor...
Old Jul 23, 2009 | 04:45 PM
thats kind of what i was thinking. i have a warranty on the motor. and since the purchase have had two replacement motors under the warranty. then i was told by everyone they would not recomend the shop i used.
Old Jul 23, 2009 | 04:53 PM
White smoke = coolant
Black smoke = fuel (running rich)
Blue smoke = oil
The black smoke could be caused by a faulty MAP sensor. Is the LED on the ECU under the front passenger carpet blinking a trouble code?
The biggest concern is the white smoke, which may indicate a blown head gasket.
Old Jul 23, 2009 | 05:21 PM
ok well the smoke is not exactly white. it has a blue/gray tint to it
Old Jul 28, 2009 | 07:55 PM
norbster86's Avatar
Check the compression and see if all the readings are the same.
Old Jul 30, 2009 | 06:30 PM
Mr Mobsta Man's Avatar
Compression numbers aren't going to be the same, not even on a new motor. Difference between cylinders can be about 20% of each other. Bad compression isn't going to cause it to run rich either (the black smoke).
Old Jul 31, 2009 | 08:05 AM
i have an update. there was a broken vacume line to the map sensor. that once i picked up from the shop i fixed my self. now the car idles and runs great no more black smoke and the blue smoke is down to a minimum on a high rev ( i know it still smokes) a bit but at least i can drive it now.
Old Jul 31, 2009 | 08:38 AM
That's great. Was the ECU LED blinking a MAP sensor code or other trouble codes?
Old Jul 31, 2009 | 11:52 PM
yea the shop told me the ECU was blinking map sensor codes. now i need to take the car back to the shop to get the blue smoke problem fixed. weather they fix or replace the motor is up to them. i still have at least 4 month left on the warranty. so i will keep you all posted
