Help!!!Replacing the compressor, drier and expansion valve of Civic 98
Old Jul 30, 2009 | 05:52 PM
mike2009's Avatar
Smile Help!!!Replacing the compressor, drier and expansion valve of Civic 98
I have gotten the tools I needed, but I don't know the steps to
get to the compressor and drier .
And the bolt seems to be very tight ..
any suggestion?
Old Jul 30, 2009 | 06:04 PM
Download the 96-98 Civic service manual at the Manuals link in my signature. The A/C chapter should prove invaluable to you.
Old Jul 31, 2009 | 05:39 AM
If your old compressor suffered catastrophic internal failure, I would also suggest a new condenser. The condenser will be full of little bits of the blown compressor, which are basically impossible to remove.
Pull the condenser / fan assembly first and access to the compressor is much easier. If equipped, also remove the power steering pump-- but do not disconnect the fluid lines, just unbolt it from the engine and move it aside.
Old Aug 2, 2009 | 04:17 PM
mike2009's Avatar
How to determine if the compressor was severely damaged and genereate a lot of debris to the condensor? And what type of condensor , parallel flow ? I am not sure .
If I need to change the condensor , how about the evaporator ? If so , it seems I have changed every main component of the whole system, then do I need to flush the system ?
Thanks your guys so much
civjosh
Oct 10, 2012 01:01 PM
SunDog67
Jul 30, 2012 02:53 PM
mike2009
Aug 5, 2009 01:18 PM
mike2009
Aug 4, 2009 08:57 PM
hemicharger
Jun 9, 2008 10:10 AM
