disc brakes (gsr or si?) 97 civic
Old Aug 4, 2009 | 01:20 AM
vonjason's Avatar
Default disc brakes (gsr or si?) 97 civic
ive doing some mtn driving
and want some disc brakes
what is the easier cheaper and better idea?
si breaks or gsr breaks?
with either conversion can i keep my lca? and eibach coilovers?
thanks
Old Aug 4, 2009 | 03:35 AM
Si brakes would be easier... GSR uses a different LCA bushing so idk if it would fit all that well, and i don't know if the e-brake cables would fit. From the 99-00 Si, everything should fit.
Old Aug 4, 2009 | 09:14 AM
vonjason's Avatar
gsr breaks are bigger though which means more power has anyone done this conversion?
if theres i way that isnt to reiculous id like to know it
thanks destruction i might just go with the si
i could still use my suspension either way right?
Old Aug 4, 2009 | 03:00 PM
I thought Si brakes and GSR brakes were the same size. Don't quote me on that though.
Old Aug 5, 2009 | 12:47 PM
vonjason's Avatar
can anyone second that?
are si and gsr brakes the same size? are they the same?
Old Aug 5, 2009 | 12:52 PM
no the gsr's are bigger
Old Aug 6, 2009 | 12:30 AM
vonjason's Avatar
so has anyone done the gsr conversion and or si conversion?
do they bolt right up or what?
Old Aug 6, 2009 | 12:37 AM
Si bolts up, already told you
Old Aug 6, 2009 | 09:46 AM
vonjason's Avatar
my bad that should be a no brainer for me anyways they came off my series car
what about gsr breaks? anyone
Old Aug 6, 2009 | 10:44 AM
GSR uses a longer rear LCA and a wider LCA bushing. I don't know if it would place it in the right spot, and you'd have to use washers to fill in the gap due to having the wider LCA bushing bracket on the trailing arm.
