disc brakes (gsr or si?) 97 civic
ive doing some mtn driving
and want some disc brakes
what is the easier cheaper and better idea?
si breaks or gsr breaks?
with either conversion can i keep my lca? and eibach coilovers?
thanks
thanks
gsr breaks are bigger though which means more power has anyone done this conversion?
if theres i way that isnt to reiculous id like to know it
thanks destruction i might just go with the si
i could still use my suspension either way right?
GSR uses a longer rear LCA and a wider LCA bushing. I don't know if it would place it in the right spot, and you'd have to use washers to fill in the gap due to having the wider LCA bushing bracket on the trailing arm.
