Which B16a is this??
Old Aug 17, 2009 | 07:33 PM
tcout's Avatar
Default Which B16a is this??
this is my b16a engine. on the block it says b16a with 5403879. This thread says it is this - 1992- 170hp 5th and 6th gen SiR, SiRII and CRX delsol SiR. Is this thread correct. here is the link. it also has a Y21 tranny.
http://www.automotiveforums.com/t16608.html
Old Aug 17, 2009 | 07:38 PM
tcout's Avatar
the previous owner told me its either from a 94 delsol or a 99 civic si. i dont know which engine i have. is it one of these or the 170hp one from 92 del sol?
Old Aug 17, 2009 | 08:38 PM
PunisherInOKC's Avatar
B16A
Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
* VTEC
* Found in:
* JDM Honda Integra RSi/XSi (DA6/DA8)
o 1988-1991 JDM Honda CRX SiR (EF8)
o 1988-1991 JDM Honda Civic SiR (EF9)
+ Displacement: 1,595 cc (97.3 cu in) 1.6 liter
+ Compression: 10.2:1
+ Bore: 81.0 mm (3.2 in)
+ Rod/stroke ratio: 1.745
+ Power: 118 kW (160 PS; 158 bhp) @ 0 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
+ Transmission: S1/J1/Y1
|33|x|2|mm|in|abbr}}
o
+ Transmission: S4C/Y21 (Some with LSD)
+ Redline: 8200 rpm
Old Aug 17, 2009 | 09:45 PM
tcout's Avatar
Dude, ur a savior. What's the engine serial for.
Old Aug 17, 2009 | 10:08 PM
tcout's Avatar
How do you tell if it had LSD? Where do u look?
Old Aug 17, 2009 | 10:10 PM
Someone correct me if I'm wrong. But from what I've been told - it is the identity of your block. Its own vin if you will. If you call Honda and tell them your block ID, they can tell you the vin of the car it should be in. This is how officers find if a motor is stolen or not.
cadman421
EK Swaps
May 11, 2007 12:47 AM
rdas45
Mar 19, 2007 02:16 PM
rdas45
Jun 19, 2006 12:20 PM
rdas45
Jun 15, 2006 07:06 AM
Derka
Jun 8, 2006 07:59 PM
