140/100 watt headlights on stock wires?
Old Aug 19, 2009 | 08:59 PM
crapurai's Avatar
Default 140/100 watt headlights on stock wires?
can i run 140/100 watt headlight bulbs on my factory 99 civic harness?
Old Aug 29, 2009 | 09:29 PM
KarTuneMan's Avatar
NO.... you'll "toast" melt, fry.... whatever you wish to call it, the factory headlight bulb harness. You will need to use the trigger wire from the factory harness at the bulb, to turn trigger a relay for your high wattage bulbs.
Old Aug 29, 2009 | 09:47 PM
Yea, 140 is definitely too high.
You want to run an aftermarket relay wiring harness... I had one come with my old headlights I bought. It looks like this but instead of HID ballast connector plugs it has H4 plugs.
http://cgi.ebay.com/High-intensity-D...#ht_3241wt_941
You'll have to do some searching to find exactly what you need.
EDIT:
Like this
http://cgi.ebay.com/ebaymotors/H4-90...#ht_2293wt_941
The yellow plugs plug into the headlight bulbs, and the male H4 connectors plug into the existing factory headlight harnesses. Then the power wire goes to the battery, and the other wires are grounded.
Old Sep 9, 2009 | 02:43 AM
EKSiR99's Avatar
why go hi wattage when you can go 60/55 on some bulbs that offer the same like philips xtreme power or osram night breakers
JEH
Mar 18, 2008 12:44 PM
sbowers
Apr 26, 2007 01:45 AM
stefo
Oct 19, 2006 12:29 PM
turbob18c1
Dec 16, 2005 10:00 AM
cmasonrun
Dec 14, 2005 10:48 PM
