Tranny Shifts Hard
Old Aug 20, 2009 | 02:37 PM
dabazi22's Avatar
Default Tranny Shifts Hard
Hi Everybody I'm new to this forum, but i need help I am currently deployed to Iraq but I am home on Leave and my wife has been complaining about the car. First off it's a 2001 Civic EX 4 Door. It Has a D-17 The Trans Is Automatic ... If More info is needed Just Post What Is Needed, and I'll Reply.
Symptoms:
1.When Stopped On A Hill It Rolls Backwards With Ease.
2.Downshifts Hard When Braking
3. And Not Very Often, But Sometimes It Takes Forever To Shift To The Next Gear.
Thanks For The Help
Old Aug 20, 2009 | 09:07 PM
Tranny is going out.... Try changing the tranny fluid though
Old Aug 21, 2009 | 02:16 AM
change the trans fluid... make sure you put the right fluid back in
and DON'T PUT LUCAS TRANS STOP SLIP HARD SHIFTING FLUID INTO IT OR ANYOTHER FLUIDS IT WILL MAKE IT WORSE.
Old Aug 21, 2009 | 12:07 PM
dabazi22's Avatar
I changed the tranny fluid and that helped alot. Can I take it to a Tranny Place to get Fixed And How Much Will It Cost?
Old Aug 21, 2009 | 01:13 PM
Is the dash D4 light blinking or does the dash CEL remain on?
Old Aug 21, 2009 | 01:20 PM
how many miles are on the car... is this the first time its been changed?
has the car been dogged? you could take it to a transmission shop and have them drop the trans and split it. replace the filter(its internal) and check the bands.
but i say that you changing the fluid fixed your problem.
did the old fluid smell burnt or look really dark..
Old Aug 21, 2009 | 01:25 PM
Also keep in mind that, when you drain the transmission fluid, more than a third of the old fluid remains in the transmission. Therefore, you could see further improvements if you drain and refill the transmission two more times (=flush). Just be sure to drive the car around the block between each drain and refill. Also make sure that you are using only Honda ATF or Honda-recommended ATF. It makes a difference.
Old Aug 22, 2009 | 09:12 AM
dabazi22's Avatar
Ok So I bought the car less than a year ago.
1. It Has 104,000 miles
2. My D4 Light Is Never Lit Either the bulb is blown or ?
3. The Civic Is Not Hot Rodded
4.THE OLD FLUID LOOKED NTHING LIKE CHERRY JUICE. IT WAS VERY BLACK. AND IT SMELLED VERY VERY BURNT
Old Aug 22, 2009 | 10:10 AM
The PO may have disabled the D4 light to hide a transmission problem. Fix the light to see if you have a transmission code. Also hook up an OBDII scan tool to see if a transmission code is being thrown.
Old Aug 22, 2009 | 03:03 PM
dabazi22's Avatar
OK Ill Take A Look At The Scanner and get back to ya I really appreciate all your help. Im thinking there might be some funny business going on from the guy i bought it from. Ill look into it.
ryan62586
May 16, 2018 10:57 AM
Drew W
May 3, 2010 01:58 PM
civic ?
Feb 26, 2008 02:44 PM
glada96EX
Jun 11, 2005 09:03 PM
02CivicEX
Jan 24, 2005 09:48 PM
