exposed cam gears?
Old Aug 29, 2009 | 02:05 PM
MBrent's Avatar
July 2010 ROTM
Default exposed cam gears?
im having some things powder coated purple to match my zex controller (valve cover, fuel rail, shifter and ****, tower bars) and im buying some purple cam gears to accent it. how do i get that gnarly exposed gear look? i didnt know if theres a trick im unaware of or if i need to just bust out the dremmel... sorry if this is a goofy question! car is basically modded out with the exception of boost, so i wanted a little individuality. purple and teal... never seen it together. hope its not too gaudy!
Old Aug 29, 2009 | 04:00 PM
Hailchristian's Avatar
take off the timing belt cover?
my engine didn't come with one so i ran it without one..not the smartest thing, but if its what you want
Old Aug 29, 2009 | 04:22 PM
hamorhead's Avatar
ive seen the cam gears you are talking about exposed before and they looked awesome IMO
and yea just take off the timing belt cover i did it on my mini-me b4 and was fine
Old Aug 29, 2009 | 04:50 PM
I would suggest to buy one of those moon cut timing belt covers. That way, it'll cover the belt, and show you the cam gears.
Just an example:
http://www.topendmotorsports.com/jp/...jdm/index.html
Old Aug 29, 2009 | 06:16 PM
hamorhead's Avatar
^thats cool
but if your going to do that you might as well take a dremel to your timing belt cover
Old Aug 29, 2009 | 06:37 PM
well IMO i wouldnt use a dremel... easiest way is a hole saw and drill... will make a perfect circle and just use a small file to smooth down the edges.
if you use a dremel chances are your holes wont be round.
Old Aug 30, 2009 | 01:51 AM
MBrent's Avatar
July 2010 ROTM
thx everybody. cam gears are ordered but powdercoating may have to wait. engine just started some horrendous noise. hope its just something loose. i dont wanna pay $800 for another b20...
Old Aug 30, 2009 | 08:20 AM
Scott53092's Avatar
Buy a clear cam cover?
Old Aug 30, 2009 | 12:21 PM
It's pretty stupid to drive without the cover. It's there for a really good reason. If you want adjustable cam gear access then cut the circles out on the side like in cvcrcr99's link.
Old Aug 30, 2009 | 03:54 PM
hamorhead's Avatar
yea that way seems eaiser
