I need help....
Old Jul 27, 2004 | 04:09 PM
PrincessD's Avatar
Default I need help....
Would someone please...(Pretty pretty please?) tell me how the heck to get the driver's side door panel off my '04 civic?
Old Jul 28, 2004 | 05:40 PM
D16z6's Avatar
Default RE: I need help....
I don't know how to take the door panel off a 2004 but i do know how for a 1994 Civic.
Old Jul 30, 2004 | 03:14 AM
LT2004ever's Avatar
could you explain how to on a 94 civic then???
Old Aug 4, 2004 | 02:11 AM
D16z6's Avatar
REMOVING DOOR PANEL FOR 1994 HONDA CIVIC: Follow all these step and you should be fine.
Remove doorpull: Unscrew the screw from the base of the doorpull and take everything out. (doorpull along with the power window )
Unpluging power window from doorpull: After removing the door pull. YOu will now have to uplug the power window. There is a tab under the doorpull you need to push on the plug to unlock it from the socket.
Remove screw under mirror: Remove the vinyl screw located underneath the side view mirror
Unscrew the door handle: Behind the door handle is a screw that attaches the back plate of the door handle to the door. The lever and locking tab will remain attached to the door, butthe plate will slide out.
Remove door panel: once everthing all out the only thing holding the door panel are sum 9 plastic clips. The only way to get it out is to pull on the door panel. WHile pulling on the panel it may seems scary. They make a scary popping noise, but pulling them hard will pop them out and release the door panel from the metal frame. Ignore the scary popping noise and jux ppull it out hard has u can but with care.
once u got all the 9 clips out jux unplug the power door lock and jux set the door panel down. Do whatever u want.
To put it back jux reverse what u did.
I tried my best to explain, but if u don't get what im saying then jux aim me or reply.
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
