EK Swaps 1996-2000 Civics
d16y7-d16z6 mini-me motor build
Old Sep 28, 2009 | 08:46 PM
WaterCake's Avatar
Default d16y7-d16z6 mini-me motor build
Hey guys, ive been doing a lot of work to my civic lately, as some may have noticed lol. I converted it from auto to stick, and then put the z6 vtec head on the y7 block. I am considering going all motor and building it up. I've been looking at parts and other info and supposedly i can easily get 160hp off of an all motor setup. I just wanted to know what you guys thought about a sohc build and what kind of gains I can expect. I'm not going to get too elaborate with it though. I'm thinking about spending a maximum of $500. Opinions please!!
Old Sep 28, 2009 | 09:55 PM
get y8 head gasket its thinner than the other head gaskets and will give more compression, also look for zc pistons, a friend of mine has a set i can get from him if you wanna buy them they will give good compression, also get a cam, and some head work done. also look into buying a lite wheight flywheel and a stage 1,2 clutch kit.
Old Sep 30, 2009 | 04:28 AM
WaterCake's Avatar
nice! my zc pistons comein tomorrow,i ordered them off ebay last week. now i didnt know about the other stuff, especially the gasket. thats goodinfo, thanks a lot!
and how much do you suppose it will cost meto do only the things youve listed there?
Old Oct 1, 2009 | 05:21 PM
WaterCake's Avatar
ok. most importantly. can you tell me exactly what i should do to the head?
more specifically, what to tell the guys at the machine shop i want done to it.
Old Oct 1, 2009 | 05:33 PM
well how much do you want to spend?
you can get alot done.
but i'd say get it ported, and shaved a little to get a clean surface and a 3angle valve job and new valve seals
Old Oct 1, 2009 | 05:42 PM
hamorhead's Avatar
itll be out of your price range but down the road get crower satge 2 or3 cam and valvetrain new IM and a header then get it tuned
Old Oct 1, 2009 | 09:01 PM
WaterCake's Avatar
well for the head, without getting new parts for it. what can i get done to it at the machine shop for better performance? and since im a noob, what is porting, resurfacing, and stuff like that?
Old Oct 2, 2009 | 04:55 AM
kanarrjl's Avatar
porting is boring the inside of the head out to allow better flow polishing would be smoothing of the ported surface to allow better flow also. resurfacing is... not positive but i think it is milling or shaving the surface of the head where it connects to the block so you have a flat surface to work with instead of a warped one and it will give you a tad bit more compression. i don't know about your town but where i live the place to have these things done is my local napa auto parts store they have a full machine shop in the back
Old Oct 2, 2009 | 07:32 AM
hamorhead's Avatar
correct sir
Old Oct 2, 2009 | 11:35 AM
WaterCake's Avatar
ok. so if i was going to get the head resurfaced, ported, and polished... would the extra money be worth the gains?
