1991 honda civic ignition...
Old Oct 14, 2009 | 06:51 PM
92maximase's Avatar
Default 1991 honda civic ignition...
hey how's it going,
the site seems pretty cool here, and hopefully i'll gain more expierience in hondas from you guys/gals.
i have a 1991 honda civic dx hatch 5-spd.
she has 173,000 miles on her runs like a champ but there's a small problem.
just recently when you go to start her up.
you go to start she starts up. once you let the key go to on everythings cuts off except the radio and blower motor, don't know bout the other accessories.
but if you hold the in start but back off enough for the starter not to keep running she'll stay on. and if you keep it like that for about 10-20seconds it's fine.
i can drive her to work (20minutes) get there shut the car off, start right back up and it's fine.
till it gets cold.
i'm thinking either main realy, ignition key cylinder...what could it be, and could the problems be repaired>?
thanks
Old Oct 14, 2009 | 07:46 PM
gwl's Avatar
gwl
Sounds like a bad ignition switch.
Old Oct 14, 2009 | 08:15 PM
the relay you can take out, open up and resolder it. they are known to crack at the soldering points, and to me it sounds like a bad ignition switch.
Old Oct 15, 2009 | 05:14 AM
The switch is a plastic piece attached to the back of the key cylinder. You don't need to replace the whole cylinder assembly, just the switch.
It isn't causing the problem you have now, but do pull your main relay and re-solder it, otherwise it's very prone to give trouble later.
Old Oct 15, 2009 | 12:50 PM
92maximase's Avatar
wow,thanks. from what 94civichatchback is showing it looks easy to remove...but looks can be deciving.
so how hard is it to remove?
Old Oct 15, 2009 | 06:35 PM
to remove the ignition switch yea its pretty easy
just take the cover off the steering column
then on the back side of the ignition there is 2 screws, then you unplug it.
Old Jul 22, 2010 | 04:27 PM
mywifeshonda's Avatar
thanks 94. your post saved me a bunch of time and cash
Old Oct 22, 2022 | 03:13 PM
kaulike kawamoto's Avatar
[QUOTE=94civichatchback;678233]to remove the ignition switch yea its pretty easy
Attachment 15901C[/ can you explain the colors on the back to me please I’m trying to wire a push button start
becken
May 29, 2010 08:03 PM
mycivic
Dec 2, 2005 06:01 PM
mycivic
Nov 10, 2005 06:52 PM
mycivic
Nov 10, 2005 06:49 PM
Patrick
17
Sep 27, 2005 10:21 AM
