EK Swaps 1996-2000 Civics
d16y7 build gone wrong!!!
Old Nov 11, 2009 | 06:35 PM
WaterCake's Avatar
Default d16y7 build gone wrong!!!
ok guys let me lay down the info.
d16y7 block
d16z6 vtec head
brand new z6 dizzy
new rod bearings
new head gasket
new zc pistons
.04 shaved head
we put it together and cranked it up. it knocks when i first start it up, but it idles fine. no knocking when accelerating slowly. when i give the throttle cable a quick pull, it knocks again. we double checked the rods, checked the timing, took the head off to see if the valves and pistons were touching. everything looked normal. nothing was touching. what could it be??????? please help!!!!!
Old Nov 11, 2009 | 07:44 PM
is it a knock or a ping? becuase usually when you get real high compression it pings
can you get a audio/video of it running?
Old Nov 11, 2009 | 08:04 PM
WaterCake's Avatar
its more like a loud click/clank. umm the only camera i have around is my cell phone but idk how to get that on here from my phone.
Old Nov 11, 2009 | 08:58 PM
txt it to your email, then email it to me, mitchkaren1225@yahoo.com
can you determine where its coming from? top or bottom?
have you tried also to pull 1 plug at a time to see if it stops and try to see what cyl its coming from?
Old Nov 11, 2009 | 09:36 PM
WaterCake's Avatar
ok i sent it directly from my phone. let me know if you get it
Old Nov 11, 2009 | 10:52 PM
WaterCake's Avatar
we think its coming from somwhere in the head. we pulled each plug one at a time to check, but it continued making the sound.
Old Nov 12, 2009 | 06:06 AM
ok i got the clip, but really hard to hear, do you have the exhaust off? i would pull the valve cover off and check the head,
Old Nov 12, 2009 | 07:19 AM
WaterCake's Avatar
yeah i feared it would sound terrible. my cell phone has a crappy mic lol.
weve looked underr the valvve cover and reassembled everything in there like 4 times. everything looks normal, but we stilll hear the sound.
were stumped =/
Old Nov 12, 2009 | 03:28 PM
idk about the head, did you get it from a person you can trust?
i wanna hear this thing run good, try a compression test see if maybe you have a bent valve or something
Old Nov 12, 2009 | 07:57 PM
WaterCake's Avatar
the valves are fine. we did the compression test before we installed the pistons. weve checked the head countless times. we tried increasing the fuel pressure and moved the distributor around a little bit. the sound got much quieter, but its still there. the only problem is the car drives sorta crappy. it feels like it has power, but somewhat chokes itself up and doesnt respond too well to throttle. any ideas?
