Removing rear door inner panel
Old Jan 16, 2010 | 07:25 AM
ugh3012's Avatar
Default Removing rear door inner panel
The child lock is on, and the door handle is broken. I need to be able to remove the inner door panel for the rear driver side door, which is stuck in closed position to replace the door handle.
If I was able to get the door to open, then I can google for the rest of the instructions.
Any idea how?
Old Jan 16, 2010 | 09:11 AM
Em1Sleeper's Avatar
Your kinda screwed there but first try opening the front door and see if you can get to the hinges for the back door. If you can take the bolts out and open the door some to pop the door panel back some to engage the door handle. Might work if not rip the door panel off, pop the door open and buy a new panel....Good luck
Old Jan 16, 2010 | 10:47 AM
ugh3012's Avatar
Is it possible to destory the door handle from the outside to acces the rod to pull it open? I have a new door handle that will go in.
Old Jan 17, 2010 | 02:15 PM
ugh3012's Avatar
bump. Any idea?
Old Jan 17, 2010 | 06:51 PM
Superfly's Avatar
take to a lock smith or somebody and have him jimmy it open. This exact thing's happened to four out of four civic back doors.....the guy i took it to had both doors opened in about five minutes.
Old Jan 17, 2010 | 08:10 PM
ugh3012's Avatar
Thanks, I will give them a shot on Wed.
darren509
Nov 21, 2011 08:15 AM
dukevalentino
Feb 20, 2011 06:30 AM
because
Aug 14, 2008 05:41 PM
addiction2bass
Mar 10, 2008 02:04 PM
WendyBlu
Jun 29, 2005 05:36 PM
