Haynes Manual Wrong??
Old May 20, 2010 | 10:59 PM
joespaghettio621's Avatar
Default Haynes Manual Wrong??
I have a 2000 Civic EX 2d 1.6L. As far as I know it is NOT a VTEC engine because nowhere on the car or engine does it say "VTEC". However the small plate on the front of the engine says the engine code is D16Y8 and according to my Haynes manual, it says that this code is a VTEC engine. Also the 4th, 5th and 6th digits of the VIN # are EJ8 and my Haynes manual says that this is a 3 or 4 door/D16Y8. Is this a mistake in the manual or do I actually have a VTEC engine?
Old May 20, 2010 | 11:09 PM
Sigracer10's Avatar
an ex engine in a vtec engine. the y8 engines are all vtec
Old May 21, 2010 | 12:48 AM
ex's are vtec. d16y8 comes in ex's so its 2 and 4 drs
Old May 21, 2010 | 04:08 AM
Can't remember if it's only 99-00, or 96-00, but one of them does not say VTEC on the valve cover like the 92-95's do.
Old May 21, 2010 | 04:27 AM
MaximusFunk's Avatar
if it has a little grayish cylinder to the upper left of the valve cover than it has vtec. a 6th gen EX should have vtec unless its not the original head as mentioned above.
Old May 21, 2010 | 09:04 AM
ok thanks guys
Old May 21, 2010 | 10:43 AM
kk5150's Avatar
how come some engines have the dual vtec sol?
Old May 21, 2010 | 11:13 AM
I believe 2 solenoids means it has 3 stage vtec instead of the 2 stage which is normal in most d-series with vtec. I am not really sure how 2 stage performs differently than 3.
Old May 21, 2010 | 11:20 AM
kk5150's Avatar
ohh ok so is that because of DOHC or what?
