2007 Civic LX SRS DTC code 2-7
Old Jun 20, 2010 | 08:17 AM
mlcourtois's Avatar
Default 2007 Civic LX SRS DTC code 2-7
The following driver side srs components were activated and replaced: side air-bag curtain, side air-bag (seat), seat belt tongue set, side impact sensor (rear). SRS module was reset and crash data removed. SRS warning light still came on. Reset SRS light, and it goes off, but comes back on. Jumped the 4 and 9 pin of the ODB-II connector and SRS warning light flashes 2-7. That is, I turn ignition to position 2, SRS light comes on for 6 sec, then off for 2, then flashes 2 long flashes, then a pause, then 7 short flashes. This sequence of 2 long 7 short then repeats. The SRS DTC tables I can find don't show a 2-7 code. Am I reading the SRS codes incorrectly? Or, do I need a specific SRS DTC table to get a description of the code? Thanks in advance.
Old Jul 31, 2010 | 03:27 PM
blerim's Avatar
Default Srs code 2-7
Hey man i have the same problem the 2-7 code and i cant find the problem i reset the srs unit and i cant find out what code 2-7 mean pease help if you got yours fixt thank you blerim.
js8vv8
Sep 30, 2011 05:42 AM
darren509
Jun 29, 2009 02:52 PM
NGSP2007
Nov 26, 2007 11:14 AM
sunjay
Oct 9, 2007 08:54 PM
