ek fog light turns on/off when i tap it!
Old Jul 4, 2010 | 09:31 AM
WaterCake's Avatar
Default ek fog light turns on/off when i tap it!
as the title says, i tap it and it turns off. i tap it agaiin and it turns on. its only the drivers side fog that does it though. the passengers side works perfectly. any ideas??
and i did step by step with this diy :
https://www.hondacivicforum.com/foru...ad.php?t=65513
Old Jul 4, 2010 | 10:23 AM
Check the harness connections. Make sure everything is secure. Might be a bad bulb.
Old Jul 4, 2010 | 11:19 AM
WaterCake's Avatar
everything is good. i think i fixed it though. i opened the fog light up and i cut some wire hairs off the ground and bent the pin that sends power to the bulb and so far so good. is anyone else having the same problem though?
Old Jul 15, 2010 | 06:20 AM
GDizzle2's Avatar
i had a problem like that with my halo lights. I took the connection to the parking lights off then rewired it again and now they work fine. Make sure you have enough wire to splice together. and make sure you cover the connection point well because water and dirt will corrode the connection
rafamofon
Dec 4, 2007 07:02 PM
bakertime
Jan 12, 2007 07:25 AM
sqhertz
Sep 29, 2006 06:45 PM
addiction2bass
Jun 25, 2006 08:19 AM
plasticboob
May 19, 2006 02:01 AM
