Remove/Install '98 Autmatic Trans
Old Jul 13, 2010 | 11:41 AM
Gone in 60's Avatar
Default Remove/Install '98 Autmatic Trans
Hi all,
Have a '98 Civic EX with an Auto. I'm planning to remove the trans soon to replace a leaking rear main seal. I've read over the manual, and can visualize the process in my head. Within the last year, I've replaced the axles and the oil pan gasket, so at least I know those bolts won't be too frozen when I need to remove them.
It seems pretty straight forward in the manual, but I figured I'd ask if anyone has any tips they could pass along from experience to help avoid aggrivation.
Thank you!
Old Jul 13, 2010 | 12:02 PM
Are you sure the rear seal is leaking? Did you remove the flywheel cover and see oil dripping from behind the flywheel? Also, an improperly installed oil pan gasket will continue to leak oil. Are you sure the oil is not coming from higher up, such as the distributor O-ring, VTEC solenoid, or valve cover?
Old Jul 13, 2010 | 03:48 PM
Gone in 60's Avatar
It's definitely not the valve cover gasket (replaced recently, and not leaking, and the distributor was the first thing I checked, and checked for any other leaks - oil seeping from the filter, solenoids, etc.
The new oil pan gasket has held tight for a year, but you've got a good point on the flywheel cover - I'll pull that tonight and check it out!
Thanks!
Old Jul 13, 2010 | 03:50 PM
Also make sure you are not seeing transmission fluid leaking from the driver side axle seal.
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
teddybruckshot
May 16, 2006 12:38 PM
trihonda
Mar 31, 2005 04:27 PM
