Automatic trans to Manual trans 92-95
OK first its worth the work!!
First you want to get all your parts before starting: 5speed trans, clutch pedal asembly, break peddal assembly, Shifter assembly, manual ECM, flywheel, clutch, clutch plate, etc its all the basic stuff. the 2 things you really need to know is
1: pull the whole wire harness from under the dash and replace with a manual wire harness. dont try and cut wires and make yours fit it a lot of work and time wasted.
2: once every thing is in you note the trns mount does not match up you have two options 1: drill and cut off the frame mount and reweld back into place( most common but not advised). 2: buy a mount here is a link to one Trans mount
The rest is up to you I just got done with mine and thats the way to go I would have pics but the day I finished it my girl of 4 years left me and took it with her.
Rsporty
Feb 13, 2010 04:22 AM
mpenner
Jun 24, 2008 05:56 PM
