Intake sound???
Old Aug 13, 2005 | 06:59 PM
tmac4prez's Avatar
Default Intake sound???
I just put an AEM cold air intake on my 99 civic...sound is not realy loud...is that usuall with most AEMs...is there a way to increase the sound? Also...it came with two bypass tubes and seems like only one of the two needed to be used...is that also normal? Also...ne suggestions on exhaust...prob gonna do a catback
Old Aug 13, 2005 | 07:19 PM
civicboy01's Avatar
Default RE: Intake sound???
from what my reading skills are, i believe the only thing that will give you a sound is an exchaust and i think Greddy is your best bet
Old Aug 13, 2005 | 07:31 PM
XCM828's Avatar
You don't need 2 bypass valves for your intake. I don't have one on my AEM intake, and it is sometimes loud enough to sound like an exhaust. Try running without a bypass valve and see if that makes a difference.
Old Aug 13, 2005 | 10:03 PM
Big T's Avatar
It really depens on your rpm's. If you get over 4,000 it should be roarin'.
Old Aug 13, 2005 | 10:09 PM
ImportTuner67's Avatar
exactly, it all depends on the rpms, the higher they go the more noise you're gonna get, keep in mind this isnt an exhaust you arent gonna be making THAT much noise, if you want the sound go for a catback, greddy, magnaflow, apexi, etc., thats where you will fill your desire for that mean sound
Old Aug 13, 2005 | 10:28 PM
j_fukin_t's Avatar
which motor??? if its a b16a2 that thing will scream over exhaust, the sohc vtec aren't as loud as dohc vtec through the intake
Old Aug 13, 2005 | 11:04 PM
Nail I3unny's Avatar
its prolly either a D15B (DX, LX, and CX,), a D15Z (HX) or the D16Z7 (EX)...unless its an Si in which case itd be a B16A2
Old Aug 16, 2005 | 02:25 PM
XCM828's Avatar
I took this video a while back because I always wanted to see what my feet looked like while I was driving (don't ask why...), and in this clip you can hear the intake quite clearly because I was on a straightaway. I was shifting at around 5500 rpm I think and I got up to about 60 before I broke off.
Video
Instructions: Right-click on above link and hit copy, open Windows Media, hit Ctrl U, hit Ctrl V, hit Enter.
Edit: That's a completely stock D16Y8 with only the intake.
Old Aug 23, 2005 | 06:26 PM
maddawg's Avatar
i'm about to buy a AEM SRI i hope it sounds off loud enough that people know i have something
Old Aug 23, 2005 | 09:51 PM
except an SRI really isnt something
it should sound kinda like theres a vaccuume under your hood
