Stereo Problems
Old Aug 24, 2005 | 08:35 PM
texan's Avatar
Default Stereo Problems
I left my headlights on for a few hours today, and needed a jump to get it going again. My stereo will only diplay "CODE" and "ERR" also the CD player will not feed in discs. If you know what I can do to fix this it would be much appreciated.
Old Aug 24, 2005 | 08:37 PM
ngoti 8tor's Avatar
Default RE: Stereo Problems
I'm quite sure you need to enter the Honda stereo code into it. Do you have it on a card from Honda? It usually comes with your owner's manual.
Old Aug 24, 2005 | 08:47 PM
texan's Avatar
I am not sure what my code is. I will look some more, but if the codes are the same for all models it is an 01 EX.
Old Aug 24, 2005 | 08:50 PM
ngoti 8tor's Avatar
No, the code will be specifically for your stereo. (that's in case someone rips you off, then they can't use the stereo)
Old Aug 24, 2005 | 08:54 PM
texan's Avatar
Not sure how much knowlege you have here, but could I possibly get it if I call Honda and give them the vin?
Otherwise I am not too sure how I am going to get it going again.
Old Aug 24, 2005 | 08:57 PM
ngoti 8tor's Avatar
ORIGINAL: texan
Yes, I believe if you go to a Honda dealer, then show them your ownership, they will get you the code from Honda. I don't think you can just call them and get it because they need proof.
Old Aug 24, 2005 | 08:59 PM
maddawg's Avatar
do you rember what it started with b/c it's hidden in a number under you hood by all the warnings and crap it is only 6or7 numbers long but under the hood it's like 15 numbers long you just go to know where to stop
texan's Avatar
Thanks for the help.....maybe next time I will be a little smarter and turn off my lights.
Old Aug 24, 2005 | 09:02 PM
Mark's Avatar
that happend to me. i just called the dealer and read them the serial number off the radio. i thought it seemed strange that they gave it over the phone cause that defeats the purpose of the code but they did
Old Aug 24, 2005 | 09:03 PM
ngoti 8tor's Avatar
You need that code if you have a stock stereo because they're made like that for whenever the power is disconnected (same thing if your battery dies).
