Help with 97 Civic EX manual
Old 06-19-2015, 06:26 AM
EdtheChipmunk's Avatar
Default Help with 97 Civic EX manual
Okay so I bought a 2 door civic ex. I replaced the Clutch because it was beyond bad. It ran fine for a few days and then the Slave clutch cylinder blew so I replaced Both the Master and the Slave clutch Cylinder. Now, It will run but wont go anywhere. By that I mean the gears are there but I have no Pick up from 1st through 5th. For example I took it on the highway and it took me two exits to get to 55 mph. Reverse seems like it's a little high on the RPM side but it seems to work fine. So I ask what could possibly cause this?
Before I forget, I noticed that when I start the car and put it in first, then take my foot off the clutch it continues to run even though it should stall out. What would cause that to happen?
Any thoughts or ideas are greatly appreciated. At this point I'm completely at a loss. I was thinking possibly the linkage, but if it was the linkage it wouldn't be able to be put in gear right?
***Side note***
When I put it in gear and try to accelerate it revs high (almost 7k) while still barely moving.
Last edited by EdtheChipmunk; 06-19-2015 at 08:08 AM. Reason: forgot some information
honvic
10-09-2011 03:14 PM
tviewbaseball
07-18-2010 07:18 AM
sbaksh
11-28-2007 08:15 PM
BillyB98
09-18-2007 08:52 PM
Fiirkan
02-28-2007 06:56 PM
Quick Reply: Help with 97 Civic EX manual
