help with b20vtec turbo??
Old Oct 18, 2008 | 09:49 AM
aj_dm's Avatar
Smile help with b20vtec turbo??
hey guys. i have an all motor b20 vtec. im push about 217 whp and 163 tqe. i love my motor and it gets up and goes, but ive been itching about going to a turbo. but i know absolutely nothing about turbos. could anyone give me a pretty good idea of what i need to do to turbo it?
heres my set up now.
b20 block
gsr head
ctr pistons and cams
ctr valvetrain
skunk2 intake manifold and fuel rail
v2 intake
dc 4-2-1 header
jackson racing highflow cat
tanabe medalion cat-back
any feedback would be great thanks.
Old Oct 18, 2008 | 10:02 AM
315 Customs's Avatar
start with a good step up. Go with something like peak boost, full race, or a turbonetics. It'll end up costing you more in the end if you get the cheap stuff. Once you have the whole turbo kit (turbo, manifold, intercooler, IC piping, oil line kit, and wastegate (depending on turbo) then you just need to get bigger injectors and a fuel management system. I would highly recommend the Hondata s300. You can actually do boost by gear with their boost controller.
Once its install find yourself a good tuner and get it dyno tuned before doing any real driving with it or you'll just blow your engine and have to start over again.
Old Oct 18, 2008 | 10:15 AM
silver wrench's Avatar
Banned
read the stickies please
Old Oct 18, 2008 | 12:57 PM
aj_dm's Avatar
ok cool. i have pretty high compression 12:1, and i heard that the wanted comp. is around 9:1? and would i have to change my internals?
Old Oct 18, 2008 | 12:59 PM
jpnolan's Avatar
you definatley should! or run super low boost
Old Oct 18, 2008 | 01:07 PM
aj_dm's Avatar
any suggestions on internals?
Old Oct 18, 2008 | 04:41 PM
bigolsackapoo's Avatar
Have you considered nitrous? That might actually be better for you.
Old Oct 19, 2008 | 05:53 AM
aj_dm's Avatar
yea i have. it doesnt intrest me as much as turbo tho. i wanna build another motor
Old Oct 19, 2008 | 06:20 AM
yea that compression is for an all motor set up
deff need to lower the compression, need to change the pistons to do that. You dont want to be higher the 9.5:1 but I would try to get around maybe 8:1 or 8.5:1
you blow your sleeves to pieces if you threw boost into your engine that is already at 12:1 CR
Old Oct 19, 2008 | 07:25 AM
aj_dm's Avatar
yea that makes sense. what about inline pro turbo kits?
good? reliable?
