quick CAI noob question
Old Aug 14, 2008 | 05:26 PM
BeitzelSi's Avatar
Default quick CAI noob question
will putting a Injen or AEM cai on a 06+ civic cause it to suck water in since it's so low to the ground after installation....?
Old Aug 14, 2008 | 06:28 PM
macbeth18288's Avatar
Oh my god
Dude, use the search feature of this forum. I do not know how many times someone has asked this question.
Old Aug 14, 2008 | 09:31 PM
the filter would have to be completely submerged in water to suck in water. buy the CAI and don't worry about it.
also, don't drive into a lake or something
Old Aug 15, 2008 | 03:52 AM
BeitzelSi's Avatar
well, is the regular CAI any different (performance wise) than a short ram intake?
Old Aug 15, 2008 | 10:48 AM
kinda. you probably get like 1 more hp with a CAI over a SRI... not enough to make a difference, especially since an SRI is cheaper than a CAI. The reason for more HP with the cold air intake is it's getting a little bit colder air than the SRI.
Old Aug 15, 2008 | 11:47 AM
cyberx32's Avatar
you can also buy a bypass if your so worried about hydrolocking
Old Aug 15, 2008 | 12:20 PM
Do you regularly drive through puddles/lakes, so much so that you would completely submerge the air filter in water? If not, you have no need to worry about hydro-locking.
Old Aug 31, 2008 | 10:39 AM
Kimosi's Avatar
First I want to say this- I thinks its funny that someone has the time to say: God, how many times have I heard this question! Go search for that! What an ***- If you have to say that just answer the dame question!
I have an 07 Si cpe and have the same prob! It doesnt like water at all. It def sits too close to the ground.
Old Sep 2, 2008 | 08:02 AM
c3o5nnect's Avatar
I believe AEM makes a cold air intake that has a bypass valve that keeps water from sucking up into the manifold. Check it out.
Old Sep 2, 2008 | 12:02 PM
a bypass valve takes back power that you gain from the CAI. With a bypass valve on a CAI, you basically are making as much power as a SRI, and the SRI costs less. therefore, bypass valves are a waste of money.
