Axles?
Old Oct 25, 2008 | 06:15 AM
jwmm04's Avatar
August 2010 ROTM
Default Axles?
So I took my '99 Si down the drag-strip for the first time yesterday, and with my luck, blew my driver's side axle. I was thinking about keeping my car off the road for a little, until I can afford some high performance axles. I was just going to replace the broken one with a stock one, but with my car's ride height, I know it's only a matter of time before it happens again. What are some good aftermarket axles? Are these any good? http://cgi.ebay.com/ebaymotors/500-h...#ht_842wt_1188 If not what are some affordable, good quality recommendations? Thanks! -JW
Old Oct 25, 2008 | 06:35 AM
315 Customs's Avatar
I think those axles will be fine. I dont know about putting 500whp to them but if your pretty much stock then they'll work fine and should hold up better then your OEM axles
Old Oct 25, 2008 | 01:12 PM
jwmm04's Avatar
August 2010 ROTM
I don't need anywhere near 500 whp, but all the ones with less hp ratings were just as expensive, if not more. They look like a nice set!
Old Oct 25, 2008 | 01:47 PM
how high/low is ur car?
Old Oct 25, 2008 | 07:26 PM
jwmm04's Avatar
August 2010 ROTM
I don't know how much, because I got the car like that, but I'm pretty damn low. I have 215/40R/16's on it, and there's almost no fender gap, whatsoever.
Old Oct 26, 2008 | 05:25 AM
can you post a pic of the car?
Old Oct 26, 2008 | 05:52 AM
well im driving this low.......
never had any axle problems yet..... but i dont have your HP i got a pathetic automatic sohc vtec thats all. but my height has no effect on the axles breaking at least not yet... been ruffly a year now.
IMO just buy a new axle from autozone or where ever that has a warente and see if you can test that warente out and break another at the track
if so just yank it out and get another free.
Old Oct 26, 2008 | 05:55 AM
yea if anything lowering should help the axles because they will be move straight then at an angle.
Old Oct 26, 2008 | 07:05 AM
jwmm04's Avatar
August 2010 ROTM
No, If you look at my axles, where they were originally slanted down from the engine, they are now pointed up, if you get what I'm saying. I'll grab some pics in a little bit.
Old Oct 26, 2008 | 05:42 PM
bcivic's Avatar
Are you sure you arent just breaking axles from wheel hop? wheel hop can cause strong oem axles to break on stock sohc motors. Preload when you race as well. Even aftermarket axles will brake due to wheel hop
