Rattle underneath car in reverse '00 civic
Old Sep 30, 2008 | 09:52 PM
inthezoneac's Avatar
Default Rattle underneath car in reverse '00 civic
whenever I go in revese and accelerate it sounds like some metal is rattling. Not sure if it's related to exhaust/cat converter, but it's annoying. Only happens during reverse and never in any other gear.
Old Sep 30, 2008 | 10:09 PM
Check out the heat-shields underneath the car. They're located between the exhaust pipe and the underside of the car. They're held on with 10mm bolts. You might just take them off completely, they don't serve much purpose and are just annoying. You might need to use a wrench or ratchet wrench to get the bolts off without removing exhaust piping. There's not really enough room between the bolt head and exhaust pipe to use a plain socket wrench
Old Oct 6, 2008 | 09:02 PM
TheJGB3's Avatar
Probably the Catalytic converter heat shield. Use hose clamps like I did. Buy 4 and open them up. Attach them togther like shown, then wrap around the cat, one in front and one in back.
Old Oct 6, 2008 | 09:16 PM
jprommel's Avatar
Angry Admin
i have some input. do you have a short shifter?, because it could be the linkage touching the exhaust and that is causing the noise. im just suggesting this because my shift linkage is now touching the exhaust heat shield but only in fifth and reverse.
Old Oct 6, 2008 | 09:23 PM
^ mines in 3rd and 4th that could be it, but heat shields are notorious to come loose. Most can just come off with no worries, i'm a little weary about removing the one below the gas tank, btu it shouldn't really matter.
Old Oct 7, 2008 | 02:20 AM
no short shifter
Old Oct 7, 2008 | 05:00 AM
jprommel's Avatar
Angry Admin
well then its probably just a heat shield rattling
burgernuds
Jul 31, 2008 08:28 PM
deyjason
Apr 26, 2008 04:40 PM
johnson96hatch
Jul 1, 2007 12:16 PM
snosurfa7
May 5, 2006 08:21 AM
WrongfulWright
Mar 17, 2005 09:45 PM
