Air diverter selection all mixed up
Old Oct 6, 2008 | 08:37 AM
SEMark's Avatar
Default Air diverter selection all mixed up
Hi everyone and thanks for reading this.
I have a problem with a 1996 Civic where the button pushed for where to send the air in the car doesn't correspond to where it comes out. For example, if it's set to the floor / vent position, the air actually comes out the front window defrost. All the buttons do something, they just don't do what they're supposed to!
Is there a way to reset this?
Thanks!
Old Oct 6, 2008 | 11:09 AM
Check the mode control motor, linkage, and doors for smooth operation:
Old Oct 6, 2008 | 11:19 AM
The motor does run apparently, but stops in the wrong position. Possibly the crank arm has slipped on the motor shaft, or the gears are stripped inside. It almost has to be the motor.
I'm pretty sure the motor is on the left (driver's) side of the heater box, should be able to reach it by crawling into the floor area and look up near the gas pedal.
Superfly
Apr 29, 2009 12:37 PM
RyanEJ2
Jan 27, 2008 11:24 AM
Live_4it
May 27, 2007 11:58 AM
mill$civic
Mar 9, 2007 06:41 PM
EG93VX
Mar 15, 2006 05:38 PM
