Weight Reductions
Old Oct 13, 2008 | 10:56 PM
xsteinbachx's Avatar
Default Weight Reductions
I Don't take ownership from this at all, but I figured you would all appreciate this.
http://www.importmodifications.com/c...eductions.html
Listed below are some easily removable items:
1. Front Drivers Seat (32lbs) - Replacing the front and passenger seats with non-power or lightweight racing seats is easy. Seats like the Sparco Roadster weigh in at only 14 lbs a piece!
2. Passenger Seat (32lbs)
- The passenger seat can easily be removed by simply unscrewing the 4 bolts holding it in place. This can either be replaced by a lightweight racing seat or removed entirely.
3. Rear Seat (29lbs) - The rear seat is a little more complicated to remove than the passenger seat. When removing just remember where everything goes and it should be easy to put back in place whenever needed.
4. Floor Mats/Front and Rear (4lbs) - This has to be the easiest weight reduction available for the Civic owner.
5. Carpet with Sound Deadener (40lbs) - The carpet and underlying can also be removed for a quick weight reduction.
6. Spare Tire and Jack (38lbs)
- Another easily removable item.
Total Easy Weight Removal = 175lbs or about a 8.5hp increase on Civic base models.
Intermediate Skill Weight Reductions
The weight reductions included below can even prove more effective than some of the reductions included above. However, once you start removing these items you are taking away from the cars overall appearance and in some cases its more predominent ammenities.
7. Windshield Washer Reservoir (11 lbs when full) - Easily removable when not being used.
8. Front Hood (44lbs with insulation) - Replacing the Front Hood with a lightweight fiberglass or carbon fiber hood is a great way to remove some weight around the front end of the car. Total weight reduction will be close to 30lbs or greater depending on the aftermarket hood you choose.. If you dont intend on replacing the entire front hood you could also remove the sound dampener on the inside of the hood. This should help in cooling your engine a little.
9. AC System (27lbs)
- The A/C system is not a necessary component and can be removed. This can generate a substantial weight savings especially in warmer cooler climates.
10. Stock Batter (40lbs)
- Can be located to trunk for weight distribution and replaced with lighter weight alternative..
11. Stock Wheels (74lbs) - Can be replaced with lightweight alternatives, although normal upgrades to a larger diameter wheel 18"+ may not remove too much weight. Wheels in 16" sizes can however be found from 14 pounds.
Total Intermediate Weight Removal = up to 126lbs or about a 6.13hp increase on base model Civics.
More Weight Reductions
Stock Flywheel (20.5 lbs)
- Can be replaced with lightweight aluminum flywheels or machined down in excess of just 10lbs.
Stock Steering Wheel (7lbs)
- Can be replaced with lighter performance steering wheel with no airbag.
Passenger Airbag Removal (17lbs)
- Can save some extra weight as well. (Not recommended for normal driving)
Interior Panels
- Both the drivers side and passenger side front door panels as well as the rear panels can be removed and replaced with carbon fiber alternatives to save in excess of over 40lbs.
Stock Speakers (14 lbs Stereo, Speakers,Amp)
- With a weight of close to 2 pounds a piece these can also be easily removed. The stock stereo, amp, and subwoofer enclosure can also net a good savings in weight.
Trunk - Can be replaced with lightweight carbon fiber trunk. Savings of roughly 11kg's.
Front Dash
- Can be replaced with carbon fiber alternative netting a savings of close to 60lbs.
Replace Stock Exhaust
- There are many alternatives when replacing your Civics exhaust system. Aftermarket exhausts can weight significantly less than the stock ones.
Wiper Motors
- Although they are generally needed under almost all driving conditions they CAN be removed if need be although we do not personally recommend it.
Total Advanced Weight Removal = Approx. 192lbs or about a 9.35hp increase on Civic base models.
Weight Removal Totals
1996+ Civic Base Model- Approx. 493 Pounds Removed = 1868 Pounds or an increase of 24 Horsepower
Old Oct 14, 2008 | 05:08 AM
driftingfan's Avatar
All that for 24 hp, doesn't really sound worth it.
Old Oct 15, 2008 | 03:55 PM
bretzky.6's Avatar
haha for real... But if you're into it, then go for it. I would never do all that.
Old Oct 15, 2008 | 04:16 PM
^it's good info if you're building strictly a track car
Old Oct 15, 2008 | 05:31 PM
9. AC System (27lbs) - The A/C system is not a necessary component and can be removed. This can generate a substantial weight savings especially in warmer cooler climates.
...warmer cooler climates FAIL.
Old Oct 15, 2008 | 05:49 PM
Hah, if you do remove the ac rool the windows down. But yea good write up, but not for an everyday civic.
Old Oct 19, 2008 | 11:44 AM
basbal123's Avatar
if you do have a dd you can go down the list and there are things here and there you can do
Old Oct 19, 2008 | 05:49 PM
SPLAT's Avatar
Sweet write up.
Old Oct 19, 2008 | 08:33 PM
ej6buddy's Avatar
As a huge note, If anyone is into auto-crossing, then check your vehicle classification before you start doing any of this. Some of the items on that list will push you into higher classes (whether you like it or not).
DickG.
May 23, 2008 02:44 PM
mill$civic
Sep 27, 2005 01:06 PM
.adrian.
Aug 14, 2005 03:39 PM
Amanda
Interior DIYs
Apr 18, 2005 12:29 PM
the_reptilian
Sep 29, 2004 10:53 AM
