Oil leak cleanup, please help!!!
Old Nov 26, 2008 | 05:38 PM
5thGenTuner's Avatar
Question Oil leak cleanup, please help!!!
I just bought a 93 civic d15b7 at. It has an oil leak and was obviously driven for a while like this. I plan on eventually swapping the engine, but until I get the money I need to fix it and clean everything up, because I can't leave my civic looking the way it does. I am pretty sure that the oil leak is from the valve cover gaskets and it has gotten everywhere it could run down to over time. I need to piece by piece take effected parts off and clean them, but I don't know where to start. Any suggestions???
Old Nov 26, 2008 | 09:48 PM
What I would do is get a valve cover gasket kit (spark plug tube seals, valve cover gasket, bolt grommets) because you probably need it anyway, and then degrease the engine bay. Check again a few days later and see if the leak is gone. If it isn't, it should now be easy to tell where it is coming from.
Old Nov 27, 2008 | 06:17 AM
93ċiviכֿ's Avatar
clean your engine bay. then you can buy this stuff you put in your oil and it glows like a green under a black light. you will know exactly where the leak is. the stuff comes in a kit including the light. safe to put in anything. use for any leaks ( radiator,oil,ect)
Old Nov 27, 2008 | 09:34 AM
Originally Posted by 93ċiviכֿ
then you can buy this stuff you put in your oil and it glows like a green under a black light. you will know exactly where the leak is. the stuff comes in a kit including the light. safe to put in anything.( radiator,oil,ect)
I'd be pretty skeptical about putting anything like that in the oil... they also say that radiator stop-leak is safe, but it's actually really not good for the system.
Old Nov 27, 2008 | 09:39 AM
civicexracer's Avatar
some high strength brake cleaner works great for getting built up oil/grease off. spray it on and wipe off. just try not to spray it on the paint, it can ruin it. also use in a well ventilated area, stuff is real strong on the nose..
theRDRman
Nov 28, 2011 04:18 PM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
Chimera02EX
Feb 4, 2006 12:54 PM
