Which controls compression and exhaust stroke
Old Oct 8, 2008 | 08:48 AM
ccwhit7's Avatar
Default Which controls compression and exhaust stroke
Does the head control the compress or the crank. Reason i ask is i ahve an engine in two pieces. Want to make sure number one is correct before installing head new belt going on with process. So how do i know for sure when number one cylinder is tdc on compression or exhaust stroke or if number 4 is on compression or exhaust stroke with no head attached.
Both pistons are tdc at same time ????
Old Oct 8, 2008 | 09:02 AM
What engine?
Crank TDC1 = mark on crank gear aligned with pointer on block.
Cam TDC1 = cam gear arrow pointing straight UP and horizontal lines aligned with top of head.
Old Oct 8, 2008 | 09:20 AM
ccwhit7's Avatar
Hi ron ,
Crank pointer alinged with pointer and cam is alinged Both are Separated at the time . It isa 94 civic with a D16Z6
Just want to make sure i dont assemble with it 180 off
Old Oct 8, 2008 | 12:17 PM
If the timing belt is installed with the cam and crank simultaneously positioned as I mentioned, then the mechanical timing will be correct.
Old Oct 8, 2008 | 12:45 PM
ccwhit7's Avatar
Thanks ronj You actually help alot in my build thru search
guate2006
Dec 17, 2008 02:24 PM
rit14623
Jan 9, 2008 09:42 PM
stylincompact
Mar 4, 2007 09:14 PM
Jeremy102579
Nov 24, 2006 07:06 PM
b18crx_89
Oct 8, 2006 02:52 PM
