Radiator replacement/d15b7
Old Oct 7, 2008 | 08:21 PM
rit14623's Avatar
Default Radiator replacement/d15b7
I got a radiator that is leaking. 1995 Civic LX/d15b7 engine. I see anti-freeze on the radiator fan and on top of the radiator, but it's not leaking a lot.
My questions are:
1. Is it easy to replace a radiator?
2. Where should I get a replacement radiator and hoses?
3. Can I get a two-row radiator for an EX or will that not fit my single row radiator for an LX?
Old Oct 7, 2008 | 09:17 PM
Are you sure the radiator is leaking as opposed to the radiator cap or reservoir?
Old Oct 8, 2008 | 11:13 AM
Could just be the connection for the top hose leaking. Clean all the antifreeze off and then watch closely for where it first starts to leak out. If it's the hose, tighten the clamp and/or replace the hose.
The radiator is easy to replace. After disconnecting it (the water hoses, the fan plug, and the transmission cooler lines if the car is automatic), take the two brackets off the top and lift the radiator and fan out as a unit. Swap the fan over to your new radiator and install it.
Old Oct 8, 2008 | 11:38 AM
ditto
that's what happened to my radiator, except when i carefully tightened it, the plastic at the radiator port was so brittle that it just collapsed and made it worse. I had to replace the radiator after that.
Hopefully yours doesn't crack. Make sure to be careful when tightening, and don't overtighten.
Hanoihancock
Jun 3, 2012 01:14 PM
srdaniel
Nov 8, 2011 09:04 PM
Kehoe
Mar 6, 2010 07:32 PM
GhostSi
Sep 29, 2009 05:23 PM
civicpimpin
Jul 15, 2008 12:47 PM
