Engine
Old Apr 28, 2004 | 01:46 PM
  #21
green98lxsedan's Avatar
Default Engine
another brit. jsut take it easy on the nos and u should be fine.
Old Apr 28, 2004 | 01:57 PM
  #22
lilol89crx's Avatar
Default Engine
a stock d15can hold up to a 50 shot with no other mods or timing adjustments as long as you know how to use it. with a 65 shot, timing will need to be retarded roughly 2 degrees. on a 75 shot it is recomended you upgrade the fuel pump and retard timing 4 degrees. ive found the on a 75 shot zex wet kit, 47psi fuel pressure at idel with vac not connected, timing retarded 3 degrees, it runs fine on a stock d15. ive had the kit on that car for roughly 8 months and it held up fine. compression #s' dropped roughly 10 acroos but what do you expect outta a d15.
Old Apr 29, 2004 | 09:48 AM
  #23
polo708's Avatar
Default Engine
Im not big on NOS, I guess its cool if you want to drastically cut the life expectancy of your engine, but i've never been a fan... especially in a daily driver car. save your money and go for the turbo/S/C. And a 50 shot is like nothing IMO.
Old Apr 29, 2004 | 10:22 PM
  #24
slim11420's Avatar
Default Engine
if you want your car to be REALLY fast....put stickers all over it along with racing stripes!!!!
Old Apr 30, 2004 | 05:48 AM
  #25
polo708's Avatar
Default Engine
Ill try that thanks<IMG src=smileys/smiley2.gif border="0">
Old Apr 30, 2004 | 07:24 AM
  #26
Roentgen's Avatar
Default Engine
Stickers will only fool the onlooker but when that person wants to see the inside of your engine, what r ugonna tell them... 'um I'm too busy at the moment'... LOLs <IMG src=smileys/smiley1.gif border="0"></P>
Old Apr 30, 2004 | 12:58 PM
  #27
lilol89crx's Avatar
Default Engine
</P>
just tell them "u cant handle whats under the hood" <IMG src=smileys/smiley2.gif border="0">or you could remove the head and show them the inside of ur engine<IMG src=smileys/smiley11.gif border="0"></P>
Old May 2, 2004 | 11:19 AM
  #28
Importman04's Avatar
Default Engine
if you want to put NOS on it i would recomend building the engine up first ior you could just do what the other guy said to do. A good exhaust for yoiur car would be the Skunk2 catback with a high flow cat, and a good CAI would the injen or AEM.
Old May 3, 2004 | 06:13 AM
  #29
polo708's Avatar
Default Engine
Skunk2 makes some of the best engine parts for hondas. any part
Old May 3, 2004 | 07:10 PM
  #30
ImportKid's Avatar
Default Engine
true there skunk2 civic was tight but yea Nos should only be to get rid off turbolag cuz a big snail on a civic is just aw dropping
