Listen up 7G's
Old Jan 10, 2006 | 05:58 PM
mxs's Avatar
mxs
Default RE: Listen up 7G's
gotcha. So what are the advantages to the conversion? I think you've mentioned it before, but... give us a reminder
Old Jan 10, 2006 | 06:06 PM
Chimera02EX's Avatar
Y8 manifold is log style manifold, with the TB side-mounted, allowing for much better flow compared to the top-mounted TB D17 IM. Doing the conversion makes the return fuel conversion easier bc you don't have to custom modify the fuel rail and allows the use of a FPR (in my case this will help greatly with my NOS kit (and it is a N.O.S. kit so I'm not just mistaking N2O for NOS)); I had an idea on how to install the dry kit on the D17 but when I put the 'vic away for the winter I decided that this would be ideal time to do this conversion; basically taking the safe route and installing the dry kit by the book. Oh yeah and prolly the best advantage to this conversion is the Y8 IM isn't PLASTIC! The Skunk2 IM also has bungs for N2O wet kit(plans for that much later).
Old Jan 10, 2006 | 06:13 PM
mxs's Avatar
mxs
wow, sounds like a plan! so th Y8 fits on there?
Old Jan 10, 2006 | 06:23 PM
dj_ipirate's Avatar
im lost.[&:]
Old Jan 10, 2006 | 07:21 PM
Yes it will fit with some modifications, I believe that on the IM the holes for the bolts need to be drilled out and re-tapped, the rest is mainly electrical and sensor modifications.
You can also use the Y8 ARP head studs on the D17 from what I hear.
Old Jan 11, 2006 | 01:38 AM
97civicturbo's Avatar
So are you going with a skunk2 mani then or a stock one?
Old Jan 11, 2006 | 05:50 AM
Civic98ex's Avatar
good luck on you new project.
Old Jan 11, 2006 | 07:24 AM
Yes I'm going with the Skunk2 IM and 66mm TB, AEM fuel rail and AEM FPR, already have a Walbro 255 pump, not 100% sure what intake I'm going with but I've been looking at the Weapon R Secret Weapon.
Old Jan 11, 2006 | 08:35 AM
Remmy's Avatar
It does MXS, I could do it on my 00 DX car.
Old Jan 11, 2006 | 09:08 AM
mill$civic's Avatar
wow man you have been learning alot, i notice when you post you no more and more about this stuff
