Overboring
Old Mar 20, 2006 | 12:15 AM
Kedawei's Avatar
Default RE: Overboring
Into an open deck I presume. Is it possible to sleeve a closed deck block? Perhaps by removing the sleeve that's already in it and putting in a stronger one?
Old Mar 20, 2006 | 12:18 AM
Marty's Avatar
Yes you have the right idea
Old Mar 20, 2006 | 12:23 AM
Kedawei's Avatar
Ha, you're my hero Marty. I'll save ya a race next time I come through gorgeous TN.
Old Mar 20, 2006 | 12:36 AM
Marty's Avatar
Glad I could help
Old Mar 20, 2006 | 12:13 PM
97civicturbo's Avatar
doesn't a block guard do a similar function?
Old Mar 20, 2006 | 01:24 PM
Kappa22's Avatar
Yes. Blockguards stabilize the tops of the sleeves to prevent lateral motion. However (expecially in high-boost applications) they can inhibit coolant flow, allowing the tops of the sleeves to develop hot spots and possibly give out.
Old Mar 20, 2006 | 04:43 PM
Nail I3unny's Avatar
correct me if im wrong, but having a large bore and a less-than stroke gives you power to high RPMs right? i thought thats basically how F1 cars rev that high. short strokes and wide bores with mind-****ing CRs. is that right or am i just crazy?
Old Mar 20, 2006 | 05:52 PM
Kedawei's Avatar
I don't think bore affects the ability to rev. Actually I would think a smaller bore could rev higher. Bore is just for power. Short stroke does allow higher revs though.
Someone correct me if I'm wrong.
Old Mar 20, 2006 | 05:55 PM
ef4life's Avatar
i believe your refering to the rod stroke ratio. long stroke engines don't rev that higgh because of the fast piston speeds at high rpm, so longer rods and shorter stroke give less piston speed and more high rpm stability. they also have less cylinder wear i hear
Old Mar 20, 2006 | 05:58 PM
yes thats what i was referring to. it makes sense when you describe it like that.
