Gutting a cat...
Old May 26, 2004 | 12:00 PM
FizzGiGG's Avatar
Default RE: Gutting a cat...
ORIGINAL: polo708
sorry, im bad at reading the whole post[sm=smiley2.gif]
I usually am too. If a post get's too long I get lazy.
So what I am thinking is that the gutted cat would probably cut out some noise but enhance another. Probably not what I am looking for.
Old May 26, 2004 | 03:06 PM
green98lxsedan's Avatar
yea gutting or removin a cat will make it louder. if thats what u want then go for it. i heard runnin w/o cats smells bad though. on my stang i almost went with an offroad xpipe but was told it will smell pretty bad so i aavoided them.
Old Jun 23, 2004 | 11:10 AM
99civic_boosted's Avatar
I have run with a cat / gutted cat / and a bypass pipe.
I difference in sound from the cat to the cat gutted was not that much at all. Actually I can't say that I even noticed a difference volume. What I did notice was that the cat now rattled like crazy and sounded like a tin can, but not any louder. I then purchased a bypass pipe that looks like a cat (cat's are required in my state) but has no insides to it.
The positive results: Good flow, no tin can sound.
The negative results: Turns the end of my exhaust tip black.
Old Jun 26, 2004 | 04:01 AM
itsmycookie's Avatar
i drove around for a week with just a exhaust manifold
poor camry...
Old Jun 29, 2004 | 03:39 PM
NOOOOO!!!
I hope i get this to you in time. DO NOT GUT YOUR CAT. you will lose power, if you are intent on running w/o one, then buy or fabricate a racepipe that is the same size as the surrounding exhaust pipe, the change in diameter with a gutted cat willl kill the exhaust gas velocity which is critical to engine performance. this is the reason you dont want a sewer pipe exhaust system on a NA honda. if i get ambitious i might write up an in depth explanation of exhaust pipe diameter tuning, or i could cut and paste an explanation from elsewhere. let me know if anyone is interested.
Old Jun 29, 2004 | 04:03 PM
yea there is a fine line between the correct size pipes and over kill. too small or big and u kill performance. the best way i heard it described was in relation to different sized straws. but im too lazy rite now too
Old Jun 29, 2004 | 04:29 PM
NTX's Avatar
NTX
If you dont want the cat, the race pipe is the best way to go.
Old Jun 29, 2004 | 10:14 PM
this is a good explanation of pipe size tuning. To give full credit, this was posted on automotivetech.org by a user named chunky:
Backpressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Hondas need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
VI. Conclusion.
SO it turns out that Hondas don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
__________________
Old Jun 30, 2004 | 05:03 AM
NTX's Avatar
NTX
Wow.....
Old Aug 19, 2011 | 06:04 AM
KAOTIC RIDES CAR CLUB's Avatar
Default gutting a cat.
if your motor is stock i wouldnt suggest gutting the cat. because it can pull in and blow out too much air for your engine and could **** your **** up so id be careful if i were you
