EG Swaps 1992-1995 Civics
LS/Vtec or
Old Feb 27, 2007 | 10:42 AM
natecivic92's Avatar
Default RE: LS/Vtec or
ORIGINAL: Kedawei
Use a B16 head and ITR cams.
What kind of # do you think it will put out with b16 head is it worth it.
Old Feb 27, 2007 | 10:59 AM
Kedawei's Avatar
How much you want? http://forums.evans-tuning.com/viewtopic.php?t=3373
For a stock block I wouldn't hesitate to put 400whp on it with an efficient set up. For a less efficient set up, such as with a log manifold/cheap turbo, I wouldn't try to strain it past 350.
Old Feb 27, 2007 | 11:07 AM
Kedawei's Avatar
Also for a more budget build, crane has somegood cams out for LS heads. http://forums.evans-tuning.com/viewtopic.php?t=3084
As you can see, torque starts falling off immediately after 5250, whereas with the B16/ITR cam set up you can expect torque to hold steady to about 8000-8500. But that's stilla nice powerband.
Whatever you go with just make sure it's tuned well.
Old Feb 27, 2007 | 11:36 AM
The last post forum #3084 I wasn't to sure if his block was sleeved cause I read somewhere the stock ls block I got can only handle 300hp so it probley was sleeved I also read the b16 head alone adds 25 more hp to the block then stock engine.I don't really want to sleeve the block right now so I was trying to go 275-300hp.
Old Feb 27, 2007 | 11:52 AM
I was reading on how to do the ls/vtes swap and it seems pretty hard drilling for knock senor and such I was think of a rework of my ls head with some crane cams as you suggested.To make it breath a little easier.
Old Feb 27, 2007 | 12:48 PM
Kedawei's Avatar
When people say stock block with Hondas they're usually refering to the rods and pistons. Stock sleeves will handle much more than these components. The set upthat you were refering tohas stock sleeves, and forged pistons/rods.
If it were me personally I wouldn't bother with forged internals though. I assume with those power goals this is a daily driver or street/strip vehicle. If you're worried about it just either don't run it so hard on the street, or if you can't stop yourself, get seperate tunes and run the lower one on the street, and the harder at the track. The motor should last you plenty long if everything is done right.
Old Feb 27, 2007 | 02:25 PM
I just want something to play around with on the road or at times at the track nothing for the nhra or anything like that just a little street respect for now.The D-series aint for me anymore.
Old Feb 27, 2007 | 03:11 PM
Kedawei's Avatar
D series still suits me just fine.
Old Feb 27, 2007 | 04:45 PM
D-series is a great engine I want a d16z6 eg hatch bad
Booger
EK Swaps
Aug 9, 2011 10:11 PM
88civicjordan
Mar 2, 2006 09:12 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
