D16Y8 build-up
Yeah I am going to build on my sohc vtec, another ? what should I do with it for now all motor. Were should I start. And how much is it going to cost, I was think crower cam, runs about $350. but what else?
RE: D16Y8 build-up
blox and skunk2 make the best cams for honda, my opinion, and toda (expensive as hell). but get some hc pistons, upgrade the valvtrain, intake manifold, throttle body, and am ecu, and ull have a n/a sohc beast.
blox cams around 550 cam gears 200 or less itantake manifold, 270 (how much i got mine for) tb maybe 400 or less vlavetrain 200 ecu 300. dont know about the pistons though. |
RE: D16Y8 build-up
itll be a lot less for a d-series. and i dont think blox has released the sohc cam yet. but when they do, ill see if i can get a group buy.
RE: D16Y8 build-up
sacicons, I looked, i gotta d16y8. Just curious.... are they tough engines? I heard they can take a serious beating. And are they strong enough to handle a s/c ?
RE: D16Y8 build-up
yo tell you the truth most sohc can got with a beating depending how you beat it for about a year. i had a friend running sohc all motor and was spraying 100 and it lasted for a year. soo yeh.....i say the way you treat your baby.
RE: D16Y8 build-up
my baby has 64000 miles on it. Works excellent other than the rattling heat shield of the manifold [:@] [:@] [:@] [:@] [:@] GOD I HATE THAT NOISE! NOBODY WILL CLEARLY TELL ME HOW TO REMOVE IT EITHER!
RE: D16Y8 build-up
the heat shield is held on by 4 bolts...just remover the 4 bolts and it will come right off
. . . . i think if your looking directly at the heat sheild thats where the bolts are...its been a while since i took mine off ...in a Y pattern...2 on top 1 in middle and 1 in middle bottom |
RE: D16Y8 build-up
yeah, itll handle an SC, if its installed and maintained right.
RE: D16Y8 build-up
I know Im an idiot. but where is the heat shield. This is my first front wheel so the engine is a little bit different. If someone could show me the light ill be fine.
[IMG]local://upfiles/1537/9EAB6385B9C343488FBF85FCBFABC74E.jpg[/IMG] [IMG]local://upfiles/1537/64C3A94FFFF240C0BAEB21837EF0D0EC.jpg[/IMG] |
RE: D16Y8 build-up
here ya go
[IMG]local://upfiles/1604/DA9B6222761349348C440081AEF6CC99.jpg[/IMG] |
| All times are GMT -8. The time now is 03:33 AM. |
