drum to disc brake conversion... ... DONE pg 3 (no 56k)
Old Oct 16, 2007 | 08:32 AM
  #21
StifflersMom's Avatar
Cat Fuсker
Default RE: drum to disc brake conversion... ... driver's side on (no 56k)
Yeppers....the black stuff that hardens into very hard rubber like material....you can make bushings outa that...
Old Oct 16, 2007 | 08:39 AM
  #22
danomatic93's Avatar
June 2010 ROTM
Sweet, for anyone reading this for Windo-Weld info, or for how to make Poly Bushings: http://forums.trinituner.com/forums/...ic.php?t=68303
  #23
mxs's Avatar
mxs
looks good
Old Oct 16, 2007 | 11:19 AM
  #24
Everyday Getaway's Avatar
Hey danomatic, looks like it's going pretty smooth, loving the looks of it! I have a question for you, since you seem to be in the know. I just bought a rear disc conversion off of a 95 integra (at least that's what I was told) but it's all pretty rusty (trailing arms, discs, calipers, etc.) and I was just wondering how you can tell if you need to rebuild or replace your calipers? Send me a PM if you can help me out, thanks a lot, sorry to jack your thread...
Old Oct 16, 2007 | 12:37 PM
  #25
June 2010 ROTM
ORIGINAL: Everyday Getaway
Don't worry about thread jacking. I'd rather have someone stumble across this thread and get all the info they need here instead of searching for hours for one stupid answer.
So, to check the caliper:
Remove the two bolts in back of the caliper to remove the caliper from the caliper bracket.
See that the two bracket rods (part of the caliper bracket) are lubricated. (pull and let go) They almost always dry. Lube them.
Remove the pads from the caliper.
If the dust boot that goes from the caliper's piston to the caliper itself is still intact, without cracks, then the caliper is probably okay.
I'm going to upload a video of a quick "how-to"
Check back in about 10 minutes.
Old Oct 16, 2007 | 12:40 PM
  #26
Cat Fuсker
and if the little rubber dust cover is broken...well the replacement procedure will definitly remind you of trying to put a certain rubber product on for the first time ever...in the dark....without ever seeing it before)) It's just a metaphore, but it took me friggin 40 minutes to figure it out...
Old Oct 16, 2007 | 12:41 PM
  #27
June 2010 ROTM
^ditto
Old Oct 16, 2007 | 12:57 PM
  #28
June 2010 ROTM
Okay, the links will be broken until the videos are fully uploaded, but here are the links:
Old Oct 16, 2007 | 01:22 PM
  #29
mybrokenblinker's Avatar
just out of curiosity, why are you swapping?
Old Oct 16, 2007 | 01:37 PM
  #30
June 2010 ROTM
ORIGINAL: mybrokenblinker
Well, it started off 2 years ago becaues I thought it looked cool. After doing some searching I found that it'll help with braking, slightly. Then I saw I needed to replace the trailing arm bushings and the LCA bushings too. Plus, I needed to replace the rear brakes and found the most of my parts for cheap.
So.... ...I've found that the more you know about cars, the more you'll end up fixing. It's a blessing... ...and a curse.
